bigbfitz Posted June 10, 2006 Share Posted June 10, 2006 I am in the market for a new car. For a long time I had planned on getting an WRX STi but I just recently learned it has no trunk pass through. This is a huge deal to me because I am a surf fisherman and am constantly carrying 9' and 10' surf rods around with me in the summer. So then I thought why not get the GT wagon but I am confused about some things. 1) Can I get one with a stick? 2) How much can i increase the power of the engine without chipping it or otherwise doing something that will must likely end up voiding my warrenty? Thanks for any help on these ???'s Bob Link to comment Share on other sites More sharing options...
Faastlegacy Posted June 10, 2006 Share Posted June 10, 2006 1. Not a 2006 and probably not a 2007 either. You can get a 2005 w/stick however. 2. Pretty much anything you do powerwise is going to void your warranty. That's the risk you take. Link to comment Share on other sites More sharing options...
Jon in CT Posted June 11, 2006 Share Posted June 11, 2006 The 2007 GT sedan models, which will begin arriving at dealerships next month, have a trunk pass-through. A 5-speed manual transmission is standard on the MY07 GT Limited sedan. A 6-speed manual transmission is standard on the MY07 GT spec.B sedan. Here are some documents from Subaru that might help you decide whether a 2007 Legacy GT is the right car for you. 2007 Legacy GT spec.B Announcement 2007 Legacy GT Limited and spec.B "At-A-Glance" 2007 Legacy GT Limited and spec.B Standard Equipment 2007 Legacy GT Limited and spec.B Specifications As for power-adders, you could certainly install a Subaru-approved intake (see https://www.subarugenuineparts.com/product_info.php?products_id=1075) and/or replace the mufflers without jeopardizing your powertrain warranty. Subaru tends to view most modifications beyond that as powertrain re-engineering. BTW, "chipping" isn't done, per se, in Subaruland. Instead, the Read-Only Memmory (ROM), containing calibrations for spark advance, fuel enrichment, peak boost, etc. used by the Engine Control Module, is re-flashed via the standard OBD-II connector. Very slick. Link to comment Share on other sites More sharing options...
bigbfitz Posted June 12, 2006 Author Share Posted June 12, 2006 Thanks for the info. I am wondering how dramatically the intake and exhaust mods will increase the proformance. I have to say that the 07 spec B looks pretty sweet. Can someone explain exactly what that knob does? Also are Subarus sold with Sirius radios? Thanks, I am getting pumped about this! Bob Link to comment Share on other sites More sharing options...
chenc544 Posted June 12, 2006 Share Posted June 12, 2006 Intake will do nothing for you power wise. An up-pipe and down-pipe will net you some power but nothing dramatic. Most of the power gain comes from re-mapping the ECU. Check here for all your '07 LGT question. http://www.cars101.com/subaru/legacy/legacy2007.html BTW, '05 & '06 sedan both have a trunk pass-through. The '07 has the 60/40 fold-down back seats like the wagon. I don't think you need the fold-down seats for your rods but you should take them to the test drive and check. Link to comment Share on other sites More sharing options...
