Legasee Posted June 10, 2006 Share Posted June 10, 2006 Found this on HSPN videos, performing brake maintenance/upgrade on STi Brembos...hope some of you may find this helpful . http://videos.hspn.com/?videoid=44 In Taiwan now... Link to comment Share on other sites More sharing options...
Aryx Posted June 15, 2006 Share Posted June 15, 2006 Nice find! I've been meaning to find out how to change to SS lines. Thanks Legasee. Link to comment Share on other sites More sharing options...
Xenonk Posted June 15, 2006 Share Posted June 15, 2006 Nice find! I've been meaning to find out how to change to SS lines. Thanks Legasee. I posted a how-to on that Keefe Link to comment Share on other sites More sharing options...
mach_six Posted June 15, 2006 Share Posted June 15, 2006 Is he using a maxi pad to cushion the jack and the jacking point? Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted June 15, 2006 Share Posted June 15, 2006 That was really cool to watch- thanks! Link to comment Share on other sites More sharing options...
wukindada Posted June 15, 2006 Share Posted June 15, 2006 Great vids.. Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
bstieritz_GT Posted July 9, 2006 Share Posted July 9, 2006 Picture walkthroughs are good but everything just seems to "-click-" when you watch someone else do it. Great find. Link to comment Share on other sites More sharing options...
ADirtyLegacy Posted July 9, 2006 Share Posted July 9, 2006 awesome vid, but a couple of Q's 1) for the LGT, don't you have to remove the caliper to get to the pads? so wouldn't you have to use a c-clamp to push the pistons back in? 2) water to kill off/dilute spilled brake fluid?! 3) does the LGT have dual bleed screws like the STi? Kenda:dm: Link to comment Share on other sites More sharing options...
ElCoyote Posted July 10, 2006 Share Posted July 10, 2006 awesome vid, but a couple of Q's 1) for the LGT, don't you have to remove the caliper to get to the pads? so wouldn't you have to use a c-clamp to push the pistons back in? 2) water to kill off/dilute spilled brake fluid?! 3) does the LGT have dual bleed screws like the STi? Kenda:dm: Good questions man Link to comment Share on other sites More sharing options...
TSiWRX Posted July 10, 2006 Share Posted July 10, 2006 1) for the LGT, don't you have to remove the caliper to get to the pads? so wouldn't you have to use a c-clamp to push the pistons back in? Well, the thing is, Kenda, the procedure shown in the video is specific for the OEM STi Brembo setup. As such, all you'd need to do is pretty much what they show ya. On the stockers for our LGTs, if I remember correctly, it's a "swing-up" deal on the calipers. Once they're "up," you should be able to remove the pads and then push-in the pistons in preparation for loading new pads. 3) does the LGT have dual bleed screws like the STi? Again, since this is for the OEM STi-upgrades, yes, those Brembos are the same as shown, and will have outboard and inboard bleeders. If I recall correctly, our stockers are a one-bleeder per caliper deal. <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
SBT Posted July 10, 2006 Share Posted July 10, 2006 . If I recall correctly, our stockers are a one-bleeder per caliper deal. ^^ correct! SBT - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
ADirtyLegacy Posted July 10, 2006 Share Posted July 10, 2006 I was just checking to make sure the LGT brakes were "like" other brake jobs i've done be4. i must say, that Brembo setup is pretty friggin SWEET! i'll have to crawl under and inspect the LGT setup be4 i tackle it! Kenda:dm: Link to comment Share on other sites More sharing options...
TSiWRX Posted July 10, 2006 Share Posted July 10, 2006 ^ Cool! <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
iamboon Posted September 14, 2006 Share Posted September 14, 2006 very helpful Link to comment Share on other sites More sharing options...
Joon525 Posted September 24, 2006 Share Posted September 24, 2006 It looked like he put in the shim on the wrong side of the bracket but I have to watch it again to be sure, or there's something different about those lines/STi.. I'm a little surprised that they aired this with the car only being supported by a jack even though they flashed the warning to not do so. Link to comment Share on other sites More sharing options...
caramall2 Posted August 13, 2007 Share Posted August 13, 2007 C Clamp: In case someone reads this, note that you may need to use a C clamp on your calipers in order for them to fit over the rotor if you're installing new pads (note I didn't install new lines so the brake fluid was still full as I was changing pads). I had to do this on both pistons, one at a time, on each caliper (each stock caliper has 2 pistons). I put a small wood shim between the clamp and the pad to protect it. I also took out the outside pad (the pad not on the piston) to make more room for the C clamp. awesome vid, but a couple of Q's 1) for the LGT, don't you have to remove the caliper to get to the pads? so wouldn't you have to use a c-clamp to push the pistons back in? 2) water to kill off/dilute spilled brake fluid?! 3) does the LGT have dual bleed screws like the STi? Kenda:dm: Link to comment Share on other sites More sharing options...
KA81 Posted August 13, 2007 Share Posted August 13, 2007 Holy old thread batman spiderman Link to comment Share on other sites More sharing options...
ej20_ftw Posted November 14, 2007 Share Posted November 14, 2007 looks easy.... i'll have to try it this weekend.. any other threads about brake pads installation? Link to comment Share on other sites More sharing options...
05gtlimited300 Posted December 17, 2007 Share Posted December 17, 2007 make sure the bleeder valves are snug, not incredibly tight. Bleeder valve are super fragile, ive made that mistake before and completely tore apart the valve and it is the biggest PIA to get the broken one out Link to comment Share on other sites More sharing options...
2006Specb122 Posted January 13, 2008 Share Posted January 13, 2008 Found this on HSPN videos, performing brake maintenance/upgrade on STi Brembos...hope some of you may find this helpful . http://videos.hspn.com/?videoid=44 Great video! I loved it! Should be similar on the LGTs. Now tell me where we can find a video for the rotors! I know KEFEE posted a how to...but I don't think he used a high def camera crew... Link to comment Share on other sites More sharing options...
2006Specb122 Posted January 13, 2008 Share Posted January 13, 2008 C Clamp: In case someone reads this, note that you may need to use a C clamp on your calipers in order for them to fit over the rotor if you're installing new pads (note I didn't install new lines so the brake fluid was still full as I was changing pads). I had to do this on both pistons, one at a time, on each caliper (each stock caliper has 2 pistons). I put a small wood shim between the clamp and the pad to protect it. I also took out the outside pad (the pad not on the piston) to make more room for the C clamp. Anymore details on the C-Clamp deal. Any pics of the tool? Any pics of the procedure? Its the only thing that sounds confusing...everythign else loooks straight forward. thanks Link to comment Share on other sites More sharing options...
sleeper8406 Posted August 27, 2008 Share Posted August 27, 2008 cool Link to comment Share on other sites More sharing options...
