zildjiank Posted June 19, 2006 Author Share Posted June 19, 2006 I dont.. unless you are putting some massive tall and wide tires on the car.. if the two tires are similar in width and overall tire diameter size, I wouldnt change it (and I havent either) I myself did not have the car aligned when I put my new 18X8in rims w/ 245/35/18 tires on... The only difference I feel is a slight, at times drastic pull to the right depending on road conditions... I'll do the aligning after I install the suspension components... Link to comment Share on other sites More sharing options...
