ebpda9 Posted June 7, 2006 Share Posted June 7, 2006 since i got the new wheels i had some vibration during the day (especially when it's hot outside), but never at night. I had them balanced and rotated but the problem still seems to continue. i know the tires have some unveven wear so i thoght that was the noise and the vibration from, but when i had them balanced i found out i have one bent wheel. what's weird is that all the vibration and noises stop at night, or when it gets cooler outside. any ideas ? i thought a bent wheel is supposed to vbibrate all the time. Link to comment Share on other sites More sharing options...
wai_pang2 Posted June 7, 2006 Share Posted June 7, 2006 It could also be the road you travel on. try driving on the road that you get the vibrations from both day and night. Link to comment Share on other sites More sharing options...
rougeben83 Posted June 7, 2006 Share Posted June 7, 2006 since i got the new wheels i had some vibration during the day (especially when it's hot outside), but never at night. I had them balanced and rotated but the problem still seems to continue. i know the tires have some unveven wear so i thoght that was the noise and the vibration from, but when i had them balanced i found out i have one bent wheel. what's weird is that all the vibration and noises stop at night, or when it gets cooler outside. any ideas ? i thought a bent wheel is supposed to vbibrate all the time. Could be your tires, ie they start vibrating when they run warmer (like during the day). Do you notice a difference between winter/summer driving? Link to comment Share on other sites More sharing options...
ebpda9 Posted June 7, 2006 Author Share Posted June 7, 2006 i got the wheels used and the tires are worn uneven. they are summer only tires and yes the same thing is happening no matter on the roads i drive. i will put the stockers back on with the winter tires for a few days and see what is happening. Link to comment Share on other sites More sharing options...
GTsleeper Posted June 7, 2006 Share Posted June 7, 2006 tires/pressures are looking to be the problem. check & maybe lower the pressures a little. try a different set of tires. plus a "summer" tire compared to a all season or winter tire is going to be harder, with alot less give. so if the tires already have uneven/choppy waer this add to the problems Link to comment Share on other sites More sharing options...
ebpda9 Posted June 7, 2006 Author Share Posted June 7, 2006 we gotta meet oneday and see what the deal is with them. plus i might wanna lower it. Link to comment Share on other sites More sharing options...
