Guest Posted June 5, 2006 Share Posted June 5, 2006 In my 05 LGT MT there is place for 3 buttons below the side mirror adjustment knob. There is only one - windshield defroster on the left. Does anyone know P/N (if they exists) for some buttons to fill other two spots? I think that Outback VDC has a button there. I looked under the covers and there are wired sockets behind them. I'd like to have an OEM looking button to turn on/off my Blinder as well as rear fog light when I import it from Europe. Oh, ok, I found an old thread about this: http://www.legacygt.com/forums/showthread.php?t=6399&highlight=button Still wondering, if anyone knows if Outback VDC has a button there and if it can be separately ordered. Oh, more search revealed this: http://www.legacygt.com/forums/showthread.php?t=12817&highlight=vdc Alas, no P/N for the button set. And only VDC button, the fold button of course doesn't cross the pond. Link to comment Share on other sites More sharing options...
sgt Posted June 5, 2006 Share Posted June 5, 2006 Do you know if the us model is prewired for a rear foglight? Link to comment Share on other sites More sharing options...
Guest Posted June 5, 2006 Share Posted June 5, 2006 Do you know if the us model is prewired for a rear foglight? No idea, probably not. I'll wire it if necessary. Link to comment Share on other sites More sharing options...
Guest Posted June 5, 2006 Share Posted June 5, 2006 Btw, search is one's friend. Another thread about the switches, alas no part numbers: http://legacygt.com/forums/showthread.php?t=25410&highlight=vdc+switch Link to comment Share on other sites More sharing options...
Fallschirmjaeger Posted June 5, 2006 Share Posted June 5, 2006 Subscribbely,,,,but only because I Hate blank buttons when you've gotten a supposedly fully loaded car. If there was Anything that fit in one of those locations that could be used to operate a rear-fog, I'd be on it like *That!* Link to comment Share on other sites More sharing options...
Guest Posted June 5, 2006 Share Posted June 5, 2006 No part number, but the Outback VDC switch set actually can be ordered via "drill down". Here: https://www.parts.com/partlocator/index.cfm?action=getLocator&siteid=213799&chapter=ARL7523&appSectionid=2610&groupid=51866&subgroupid=2693&componentid=52736&make=32&model=Legacy/outback&year=2006&graphicID=7523445&callout=2&catalogid=2 $38 bucks, hmmm. Link to comment Share on other sites More sharing options...
SubiGT Posted June 6, 2006 Share Posted June 6, 2006 subscribble fo shizzle maybe a DRL cancel?...... Many Shuvs and Zuuls knew what it was to be roasted in the depths of the Slor that day, I can tell you! Link to comment Share on other sites More sharing options...
Fallschirmjaeger Posted June 17, 2006 Share Posted June 17, 2006 It just occured to me.... I wonder if a very subdued LED light could be added to the parkinglight switch on top of the steering column and have that used for a rear fog switch? Probably most people see the top of the column easily, but I always seem to wind up with the wheel at the very topmost of its travel arc. Guess I drove Jeeps n such too many yrs. Link to comment Share on other sites More sharing options...
dv8ingvector Posted June 23, 2006 Share Posted June 23, 2006 Just a hunch but I don’t think the switch is actually an analog 12v on/of switch...most of the buttons in are cars work through a computer via resistance changes for each command. So you would probably have to engineer a relay to use the button? Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted June 23, 2006 Share Posted June 23, 2006 Optional JDM ball massager. Link to comment Share on other sites More sharing options...
rc0032 Posted June 23, 2006 Share Posted June 23, 2006 Optional JDM ball massager. bump Link to comment Share on other sites More sharing options...
pillboy Posted June 23, 2006 Share Posted June 23, 2006 Optional JDM ball massager. Where do I get JDM balls? It is still ugly. Link to comment Share on other sites More sharing options...
dv8ingvector Posted June 23, 2006 Share Posted June 23, 2006 Where do I get JDM balls? JDM? Link to comment Share on other sites More sharing options...
