lhsa Posted June 5, 2006 Share Posted June 5, 2006 i'm having a problem with my RBS grill. it fits fine, but my hood is now crooked and the gap (looking head on the frontside) on the left side is 50% larger than the right side. does anyone else have this problem? any recommended fixes? Link to comment Share on other sites More sharing options...
Brady Posted June 5, 2006 Share Posted June 5, 2006 Well, the question I have to ask is, are you looking at the gap over the grille, or over the headlights? If it's the headlights, I doubt it's the grille, if it's over the grille that the gap looks different, then your grille isn't even. Either way, I doubt your grille caused your hood to be crooked. Link to comment Share on other sites More sharing options...
PhilT Posted June 5, 2006 Share Posted June 5, 2006 The grill is not connected to the hood at all, unless you somehow installed it wrong. If your hood is crooked, it must because the bump stops are not level, or the hinges are off. It's not possible for the grill to cause it. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
lhsa Posted June 5, 2006 Author Share Posted June 5, 2006 i'm looking at the gap in between the headlights/grill and hood/bumper. it didn't sit that way prior to the install. also, the hood requires much more force to close. That's why i assumed its the grill. i'll try to snap pics tonite. Link to comment Share on other sites More sharing options...
jagcars26 Posted June 5, 2006 Share Posted June 5, 2006 The grill is not connected to the hood at all, unless you somehow installed it wrong. +1 Link to comment Share on other sites More sharing options...
Brady Posted June 5, 2006 Share Posted June 5, 2006 i'm looking at the gap in between the headlights/grill and hood/bumper. it didn't sit that way prior to the install. also, the hood requires much more force to close. That's why i assumed its the grill. i'll try to snap pics tonite. There is no gap between your hood and bumper! I guess I'm confused what you're referencing. +1 on pics tonight. I'm curious to see what you mean. Link to comment Share on other sites More sharing options...
Scooter Posted June 7, 2006 Share Posted June 7, 2006 I remember that I had to adjust my RBS grille a little bit side-to-side to get even gaps along the sides of the new grille, but I didn't have any problems with the hood. Check the picture; everything is even and parallel. If you post pictures of your we might be able to help troubleshoot. Seek first to understand, then to be understood. In other words: SEARCH before you post! Link to comment Share on other sites More sharing options...
Rommel Posted June 7, 2006 Share Posted June 7, 2006 do you have a bug deflector? Link to comment Share on other sites More sharing options...
JBurke Posted June 8, 2006 Share Posted June 8, 2006 I have a minor gap between my grill and my front bumper on the bottom of the grill - anyone else have this problem? Link to comment Share on other sites More sharing options...
Rommel Posted June 8, 2006 Share Posted June 8, 2006 To fix the gap between the bumper and grill is to insert some kind of cardboard or foam inside the bumper to raise the bumper skin. Link to comment Share on other sites More sharing options...
JBurke Posted June 8, 2006 Share Posted June 8, 2006 Thank you soooo much. I was about to use VHB 3M tape or something haha. Link to comment Share on other sites More sharing options...
PhilT Posted June 8, 2006 Share Posted June 8, 2006 To fix the gap between the bumper and grill is to insert some kind of cardboard or foam inside the bumper to raise the bumper skin. I used one of my old socks, worked a treat Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
scans007 Posted June 8, 2006 Share Posted June 8, 2006 Yeah Like he said, a peice of cardboard, a shim......slide it under the bumper skin, I used a 7 inch long 1'' wide peice of metal......flat as can be, no problems for 5k miles, 5 minute fix Before: http://www.pimpmyauto.com/Pictures/B_RBS/Large/DSC03544.JPG After: http://www.pimpmyauto.com/Pictures/B_FMIC/Large/DSC03975.JPG Link to comment Share on other sites More sharing options...
lhsa Posted June 8, 2006 Author Share Posted June 8, 2006 finally got off my lazy azz and got a pic of the problem. the strange thing is i can't seem to even it out and it wasn't there with the stock grill. you can see the left side is about 2x the gap as the right side. i should lighten the pic, its BSM, but it looks like a specB! http://i60.photobucket.com/albums/h20/LHSA-LGT/IMG_0466Large.jpg Link to comment Share on other sites More sharing options...
scans007 Posted June 8, 2006 Share Posted June 8, 2006 I would guess that has nothing to do with the grill man, take off the grill and shut the hood, I'm betting the gap will on the pass side will still be larger, looks like the hood is just outta line a lil bit. There's nothing about install'n the grille that would affect the hood, unless someone you moved the latch somehow (which is doubtful) And, looks like you already got it shimmed Link to comment Share on other sites More sharing options...
Scooter Posted June 8, 2006 Share Posted June 8, 2006 If anything, I'd almost say that the bumper looks a little low on the right side (of the car, left side of the picture), rather than the hood being high. If you compare the outboard corners of the hood side to side it looks like they both line up beautifully with the fenders, so the hood position looks good to me. Maybe see if there's anyway you can shim the bumper to pull it up a little bit right at the spot between the grille and the headlamp? Although... this wouldn't help if you are having high hood closing efforts. Hmmm. Seek first to understand, then to be understood. In other words: SEARCH before you post! Link to comment Share on other sites More sharing options...
lhsa Posted June 8, 2006 Author Share Posted June 8, 2006 good suggestions all around! i'll check out the bumper alignment and check out the front sans grill. Link to comment Share on other sites More sharing options...
PhilT Posted June 8, 2006 Share Posted June 8, 2006 If anything, I'd almost say that the bumper looks a little low on the right side (of the car, left side of the picture), rather than the hood being high. If you compare the outboard corners of the hood side to side it looks like they both line up beautifully with the fenders, so the hood position looks good to me. Maybe see if there's anyway you can shim the bumper to pull it up a little bit right at the spot between the grille and the headlamp? Although... this wouldn't help if you are having high hood closing efforts. Hmmm. Looks that way to me too, the gap between the bumper and the passenger side headlight is larger too. Try adjusting the bumper to start with. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
TSiWRX Posted June 8, 2006 Share Posted June 8, 2006 ^ +1. <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
luvbster Posted June 8, 2006 Share Posted June 8, 2006 ^+2 Link to comment Share on other sites More sharing options...
lhsa Posted June 11, 2006 Author Share Posted June 11, 2006 update for y'all. i took a close look at the hood and it appears that the hood itself is a little crooked. maybe i didn't notice it before the RBS grill, so the grill wasn't the cause. do you think a dealer would fix/tweak the hood under warranty? Link to comment Share on other sites More sharing options...
lhsa Posted June 11, 2006 Author Share Posted June 11, 2006 the space below the headlight looks similar on both sides. Looks that way to me too, the gap between the bumper and the passenger side headlight is larger too. Try adjusting the bumper to start with. Link to comment Share on other sites More sharing options...
PhilT Posted June 11, 2006 Share Posted June 11, 2006 It might be the camera angle, but the gap on the driver's side appears smaller than the gap on the passenger side, try measuring it to be sure. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
