HansGT Posted June 5, 2006 Share Posted June 5, 2006 Front (23mm) and Rear (21mm) Cusco sways installed this past Saturday. Thanks to Rob at Maryland Turbo Solutions and his friend Doug for the install. Great work guys! Highly recommended. By the way, Rob's FMIC set up is just sick. Car sounds and looks great. ( a bit jealous ) http://www.marylandturbo.com/catalog/ Review: Well I must say my ride has really firmed up, in a good way. I had just been rolling on iON springs, which made a huge improvement over stock, but still was plagued with a bit of body roll, thus sway bars. The body roll is greatly reduced now and the car just feels more planted and secure. It's like point and go now...no jerking around in the seat. I did some quick lane changing today and was like, damn that's nice. Reminded me of my old 944. So far no squeaks or clunks. Overall, very very pleased. The car should have came from the factory like this. Link to comment Share on other sites More sharing options...
PGT Posted June 5, 2006 Share Posted June 5, 2006 I've got a front one to put on. I thought the rear alone would be enough, but I've still got some roll and the front doesn't seem quick to turn in. By the way...stock endlinks? Link to comment Share on other sites More sharing options...
HansGT Posted June 5, 2006 Author Share Posted June 5, 2006 yep, stock endlinks. I'm going to see how they hold up. Keefe used his stockers for 34K miles before thinking something was going wrong with them. So I'm going to save the cash for now. If I get clunking I may upgrade the endlinks to try and stop it. But so far so good. (fingers crossed) Link to comment Share on other sites More sharing options...
Xenonk Posted June 5, 2006 Share Posted June 5, 2006 ^ my issues is that the front control arm bushings are finally taking a beating.. so even my "clunking sounds" isn't from the endlinks at 50,000 miles now.. Keefe Link to comment Share on other sites More sharing options...
MDTURBO Posted June 5, 2006 Share Posted June 5, 2006 Also keep in mind, Keefe is "mr. autox" as well. Unless your following in his footsteps and auto-xing hard, yours should last a bit longer in theory. Those stocker end links though are pretty laughable. -Rob 2012 Forester XT. Stage 2+ Retired from Racing. I used to build FMIC and more. Link to comment Share on other sites More sharing options...
HansGT Posted June 5, 2006 Author Share Posted June 5, 2006 Also keep in mind, Keefe is "mr. autox" as well. Unless your following in his footsteps and auto-xing hard, yours should last a bit longer in theory. Those stocker end links though are pretty laughable. -Rob If I'm not mistaken their about as thick as a pencil. Link to comment Share on other sites More sharing options...
PGT Posted June 5, 2006 Share Posted June 5, 2006 I've fu><ored the threads somehow on mine from all the changes to my suspension. I knew the last time I reinstalled them, that would be the last and that the next time I removed them I'd better have a new one to replace it with. Link to comment Share on other sites More sharing options...
MDTURBO Posted June 5, 2006 Share Posted June 5, 2006 If I'm not mistaken their about as thick as a pencil. You sir are not mistaken. I'm surprised they dont bend with the stock sway, but I guess that's why the stock sway looks like a coat hanger. 2012 Forester XT. Stage 2+ Retired from Racing. I used to build FMIC and more. Link to comment Share on other sites More sharing options...
Xenonk Posted June 5, 2006 Share Posted June 5, 2006 Also keep in mind, Keefe is "mr. autox" as well. Unless your following in his footsteps and auto-xing hard, yours should last a bit longer in theory. Those stocker end links though are pretty laughable. -Rob yea, but they can take the abuse. Keefe Link to comment Share on other sites More sharing options...
HansGT Posted June 5, 2006 Author Share Posted June 5, 2006 yea, but they can take the abuse. if they've survived all you've put them through then I feel pretty safe. I'll only change if i get clunking. Link to comment Share on other sites More sharing options...
Legasee Posted June 5, 2006 Share Posted June 5, 2006 I've been debating on getting the front and rear sways for a while and since $$ was a factor, I didn't get it due to fear of the breakage of the OEM endlinks with some Cusco's or whatever...but like Han'sGT said, "if they've survived all you've put them through then I feel pretty safe" ...thanks for all the input guys! In Taiwan now... Link to comment Share on other sites More sharing options...
Th3Franz Posted June 5, 2006 Share Posted June 5, 2006 Is it really worth it to upgrade the endlinks? It seems like the mounts and other parts connected to the sway bars are not very rigid either... -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
PGT Posted June 5, 2006 Share Posted June 5, 2006 For most people, I'd do the Cobb rear reinforcment thingy (technical term) before endlinks. Link to comment Share on other sites More sharing options...
Xenonk Posted June 5, 2006 Share Posted June 5, 2006 Is it really worth it to upgrade the endlinks? It seems like the mounts and other parts connected to the sway bars are not very rigid either... only if you have bent up your stock ones Keefe Link to comment Share on other sites More sharing options...
JuxtaGT Posted June 6, 2006 Share Posted June 6, 2006 Just be careful of jacking the car up from one side now. I think Keefe mentioned it first, you can put a LOT of pressure on those endlinks now with the Cusco sway. I have a feeling that me jacking my car up every weekend to fiddle with something played a roll in the death of my endlinks. I think I hear them clunking now...... Link to comment Share on other sites More sharing options...
Xenonk Posted June 6, 2006 Share Posted June 6, 2006 it's possible to break them like so.. i just jack from the diff.. but of all my car work, i still jack from both front and rear side jacking points and nothing is broken.. just jack up slowly and lower slowly... Keefe Link to comment Share on other sites More sharing options...
chuckzul Posted June 6, 2006 Share Posted June 6, 2006 ^ my issues is that the front control arm bushings are finally taking a beating.. so even my "clunking sounds" isn't from the endlinks at 50,000 miles now.. Isn't there a company out there that makes solid, spherical press in bushings for the front control arm? I had a set like that for my old z28. Real harsh but tons of feedback and very responsive. Link to comment Share on other sites More sharing options...
PGT Posted June 6, 2006 Share Posted June 6, 2006 Perrin does, but no thanks Link to comment Share on other sites More sharing options...
Xenonk Posted June 6, 2006 Share Posted June 6, 2006 Isn't there a company out there that makes solid, spherical press in bushings for the front control arm? I had a set like that for my old z28. Real harsh but tons of feedback and very responsive. Perrin does.. I have yet to do this mod.. I might just opt to get that AND a set of Spec B aluminum control arms while I am at it for the ultimate response Keefe Link to comment Share on other sites More sharing options...
HansGT Posted June 9, 2006 Author Share Posted June 9, 2006 Update: No creaks, squeaks or clunks. Link to comment Share on other sites More sharing options...
Sexymommymissesher97 Posted June 11, 2006 Share Posted June 11, 2006 Hay Han'sGT ,So is it that much better Maybe I need to go for another ride.I am still debating what to do?But sways are a must. Link to comment Share on other sites More sharing options...
HansGT Posted June 12, 2006 Author Share Posted June 12, 2006 Hay Han'sGT ,So is it that much better Maybe I need to go for another ride.I am still debating what to do?But sways are a must. body roll is pretty much gone in everyday driving. I LOVE IT! You can still feel it when pushed in the off ramps, but not close to what it was. The springs and sways are a nice combo. I just need new tires now....the 92's are forgiving because you can feel when they start to slip, but i want more grip....maybe next spring. Link to comment Share on other sites More sharing options...
fzanetti Posted June 12, 2006 Share Posted June 12, 2006 I just need new tires now....the 92's are forgiving because you can feel when they start to slip, but i want more grip....maybe next spring. Great path... Spring Sways with or without new endlinks Tires :-) Flavio Zanetti Boston, MA Link to comment Share on other sites More sharing options...
HansGT Posted June 12, 2006 Author Share Posted June 12, 2006 Great path... Spring Sways with or without new endlinks Tires :-) Flavio Zanetti Boston, MA yeah, i wanted to do tires first, i just couldn't push convience myself to get rid of brand new ones....they'll wear out soon enough. Link to comment Share on other sites More sharing options...
MDTURBO Posted June 12, 2006 Share Posted June 12, 2006 Let me know if you're looking for a particular brand, I have an account through tire rack. 2012 Forester XT. Stage 2+ Retired from Racing. I used to build FMIC and more. Link to comment Share on other sites More sharing options...
