BigT Posted June 5, 2006 Share Posted June 5, 2006 Hey guys, I've got my JDM Pinks on, and the JDM 20mm rear sway bar. What do you guys think is the next step in better handling?-T Link to comment Share on other sites More sharing options...
axis008 Posted June 5, 2006 Share Posted June 5, 2006 Have you replaced your tires? -ben Link to comment Share on other sites More sharing options...
fzanetti Posted June 5, 2006 Share Posted June 5, 2006 Have you replaced your tires? +1 Flavio Zanetti Boston, MA Link to comment Share on other sites More sharing options...
LittleBlueGT Posted June 5, 2006 Share Posted June 5, 2006 Spec-B dampers! Big big diff! Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
team23jordan Posted June 5, 2006 Share Posted June 5, 2006 if you haven't upgraded your tires, upgrade'em then get front sway bar also. Never seen JDM 20mm but I'd stay with Cusco sways. After that you can get Spec B dampers or get a set of coilovers Perrin BIG maf intake Perrin Turbo Inlet HKS SSQV BOV Megan Racing header with UP (ceramic coated) HKS DP (WRX) DMH E-cutout Custom 3" catback UTEC Link to comment Share on other sites More sharing options...
BigT Posted June 5, 2006 Author Share Posted June 5, 2006 I've got two sets of re92s both with about 25% left on them. I just waiting for them to die out before I upgrade to some better all seasons. So a cusco front sway bar. Is anybody running one of these with a JDM rear? What exactly do dampers do?-T Link to comment Share on other sites More sharing options...
wukindada Posted June 5, 2006 Share Posted June 5, 2006 Sell the 2 sets of re92s & use the $ towards a real set;)Once you get new rubber go with a Cusco front sway. After that start looking @ braking....new lines.....pads & fluid:) Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
Daedalus Posted June 5, 2006 Share Posted June 5, 2006 For All-Seasons, I'd suggest the Avon Tech m550 A/S. www.tirerack.com has them. Link to comment Share on other sites More sharing options...
wukindada Posted June 5, 2006 Share Posted June 5, 2006 ^ Very.....very heavy tire;) Toyo T1R or Goodyear F1's:) Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
RaceComp Engineering Posted June 5, 2006 Share Posted June 5, 2006 wheels/tires cusco front sway bar - andrew Link to comment Share on other sites More sharing options...
Daedalus Posted June 5, 2006 Share Posted June 5, 2006 ^ Very.....very heavy tire;) Toyo T1R or Goodyear F1's:) Aren't those summer tires? Link to comment Share on other sites More sharing options...
team23jordan Posted June 5, 2006 Share Posted June 5, 2006 kumho ecsta ASX FTW Perrin BIG maf intake Perrin Turbo Inlet HKS SSQV BOV Megan Racing header with UP (ceramic coated) HKS DP (WRX) DMH E-cutout Custom 3" catback UTEC Link to comment Share on other sites More sharing options...
