gsepete Posted June 6, 2006 Share Posted June 6, 2006 Basicly to make a long story short here we are only dealing with 2 wires (technicaly there are 4, the remaining 4 pins on ST4. remember there are 5 and pin #5 is the horn) but 2 wires are for illumination and on AT cars that is all set and are allready wired (don't know about MT's). On the wiring diagram 5EAT legacys use 2 pins for the shift control - pins 2 and 4, and on a legacy with audio controls it uses pins 1 and 2, pin # 3 is the ground. It's just a matter of removing the 2 shift wires and splicing the 2 to the stereo. YOU STILL have to add the 2 wires because the wire that would connect to pin 1 is blank on my connector. Disclaimer - It might not be 100% but in theory I think that would work, any suggestions or corrections would be helpful and appreciatedthanks Link to comment Share on other sites More sharing options...
ercdvs Posted June 6, 2006 Author Share Posted June 6, 2006 which vacation pic details the wiring of the switches and radio ? I found one that shows the proper resistances to the connector.. but thats about it EDIT: found some useful ones ..but not all yet.. accoring to the diagram.. the at controls for a 5 sp turbo use THREE wires... pin 2(GR) 4(Sb) 3(BW) on the roll connector Link to comment Share on other sites More sharing options...
Brady Posted June 6, 2006 Share Posted June 6, 2006 I have an automatic and would rather have radio controls than shift buttons. I wish you luck. If you're serious, Mark, I am 99% certain we could do this to your car if you're comfortable with losing the shifter controls. It wouldn't take us but more than 2 hours TOPS. (Seriously, maybe just an hour). Link to comment Share on other sites More sharing options...
trabbic Posted June 6, 2006 Share Posted June 6, 2006 I have an extensive reply in the HOW TO, so that other people can get the benefit from our discussion... http://www.legacygt.com/forums/showthread.php?p=623424#post623424 My vB Garage How to Install Steering Wheel Radio Controls Cubby Gauge Mounting Solutions Link to comment Share on other sites More sharing options...
