dramsey Posted May 28, 2006 Share Posted May 28, 2006 I'm mechanically oriented and work on my cars quite often. However I can't seem to figure out how to change the oil in the front diff. on my 2005 Legacy GT (Automatic). I've bought the washer for the lower bolt to remove the oil. It also uses a size 70 Torx which I also own. I can't find the bolt to add the fluid back in. It's hidden or not obvious because I don't see it. I had the transmission done at Subaru because it required 10 quarts and I couldn't find the fluid anywhere but looking under the car I don't even see where you add that fluid either. The drain plug is point blank obvious. So if anyone can help on the location for the bolt on the front diferential, I'd be very greatful. Derek Link to comment Share on other sites More sharing options...
mbacis Posted May 28, 2006 Share Posted May 28, 2006 I believe I've read here that the automatics share front differential and transmission oils. Therefore, if you've the transmission done, you've already had the front diff. done too. Link to comment Share on other sites More sharing options...
G.T.Subie Posted May 28, 2006 Share Posted May 28, 2006 I believe I've read here that the automatics share front differential and transmission oils. Therefore, if you've the transmission done, you've already had the front diff. done too.+1 http://www.legacygt.com/forums/showthread.php?t=33603 Denial is your best friend Link to comment Share on other sites More sharing options...
Beanboy Posted May 28, 2006 Share Posted May 28, 2006 Yikes! Automatic transmission fluid is very different from gear oil... Manual Subarus share front differential and transmission oil, automatics DO NOT. Need to fill the oil through the dipstick tube. Best bet is to use some tubing...not sure diameter. -B http://www.standardshift.com Link to comment Share on other sites More sharing options...
mbacis Posted May 29, 2006 Share Posted May 29, 2006 Yikes! Automatic transmission fluid is very different from gear oil... Manual Subarus share front differential and transmission oil, automatics DO NOT. He's right, I'm wrong. It's the MT that shares gear and front diff. oils. There should be a filler plug near the drain plug on the front diff.14 - Front & Rear Differential Gear Oil Replacement.pdf Link to comment Share on other sites More sharing options...
dramsey Posted May 29, 2006 Author Share Posted May 29, 2006 Thanks for all your responses. You are right, the front differential is filled through the dipstick tube Link to comment Share on other sites More sharing options...
REM87O Posted May 29, 2006 Share Posted May 29, 2006 Drivers side is the trans fluid, pass side is the diff fluid way undwe the IC. You can reach down between the turbo heatshield to pull the stick. Good luck with the change. Link to comment Share on other sites More sharing options...
