KartRacerBoy Posted May 27, 2006 Share Posted May 27, 2006 Tried to install my new front and rear Cobb hollow swaybars. Car up on jackstands, wheels off. rears links removed from rear sway. losened bottom/outside muffler bar w/ 18" breaker bar. Can't get breaker bar on top/inside muffler to y-pipe bolt; not enough articulation. Wrenches don't give enough leverage. Nor does socket wrench. I hate mechanics with air tools. Muffler shop installed my 3" perrin center and y-pipe to stock mufflers. ARGHH!!!!! Guess I'll have to pay another idiot with airtools. ARGGGHHHHH!!! Must go drink BEER now. bye. Link to comment Share on other sites More sharing options...
mikeyan Posted May 27, 2006 Share Posted May 27, 2006 Have you tried just dropping the mufflers from the hanger... i installed the cusco RSB with a buddy by dropping the exhaust hangers, letting the hang and slowly twisting the sway bar out... and you might have an easier time, we kept the tires on the car. SoCal Duck Hunters Club - Unit 52 Link to comment Share on other sites More sharing options...
Paradiso Posted May 27, 2006 Share Posted May 27, 2006 Have you tried just dropping the mufflers from the hanger... i installed the cusco RSB with a buddy by dropping the exhaust hangers, letting the hang and slowly twisting the sway bar out... and you might have an easier time, we kept the tires on the car. +1 Its a PIA but you can snake the sway bar out with the mufflers attached but dropped from the hangers. Also a mega PIA to get the friggin hangers re-attached. Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted May 27, 2006 Share Posted May 27, 2006 I've had situations like that where I put the end of the ratchet on a floor jack and raised it to break it loose. Link to comment Share on other sites More sharing options...
KartRacerBoy Posted May 27, 2006 Author Share Posted May 27, 2006 If my mechanic will do it for less than an hour each for front and rear, I'll let his shop do it. Aggravated a tendon I once tore in my hand just trying to loosen the dang bolt and now my left hand won't be able to grip anything...ANYTHING for a good few weeks. I love working on cars. Link to comment Share on other sites More sharing options...
Th3Franz Posted May 27, 2006 Share Posted May 27, 2006 Sorry to hear that. I just used a spare jack under the Y-pipe and removed the hangers to drop the exhaust enough, then had someone help me wiggle the rear sway bar in. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
LittleBlueGT Posted May 27, 2006 Share Posted May 27, 2006 With a pry bar I can get more torque then a 600 ftlb impact. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
froggert Posted May 27, 2006 Share Posted May 27, 2006 have you tried pb blaster on the bolts or wd40 on the muffler hangers? Link to comment Share on other sites More sharing options...
Ridgeracer Posted May 28, 2006 Share Posted May 28, 2006 ^+1 on the WD-40 for the hangers. VEEEERYYYY easy after that. BTW def. drop the mufflers from the hangers first before pulling the RSB. "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
Deer Killer Posted May 28, 2006 Share Posted May 28, 2006 WD-40 = crap, PB-blaster FTW. Seriously. Link to comment Share on other sites More sharing options...
froggert Posted May 29, 2006 Share Posted May 29, 2006 pb blaster > wd-40 for bolts. never tried pb on hangers. Link to comment Share on other sites More sharing options...
meier motor sports Posted May 29, 2006 Share Posted May 29, 2006 pb is greater then all in all situations and mr kart boy all you need is a bigger wrench. Link to comment Share on other sites More sharing options...
KartRacerBoy Posted May 31, 2006 Author Share Posted May 31, 2006 Don't call my wrench small. Insulting. Seriously, the problem was that I couldn't get my breaker wrench on the bolt. Too much interference from various parts of the car. The breaker got one bolt off fine. I'm just too dense sometimes (and in too much of an impatient rush to go to my brother in law's pool) to thing of things like penetration agents. This is why I stick to little cars like karts. No air tools go near my karts. Wrist much better, btw. I used beer, Jim Beam, and martinis as penetrating agents to lube up my sore tendon while soaking it in an 86 degree pool this Memorial Day weekend. Still not good enough to wrench on my car, but at least I can now do important things again like pick up my 3 yr old daughter. Life is good and goes on. Link to comment Share on other sites More sharing options...
Xenonk Posted May 31, 2006 Share Posted May 31, 2006 PB blaster will fix it. Keefe Link to comment Share on other sites More sharing options...
wcbjr Posted June 1, 2006 Share Posted June 1, 2006 I've had situations like that where I put the end of the ratchet on a floor jack and raised it to break it loose. Yep. I've done that before. http://www.legacygt.com/forums/showpost.php?p=543855&postcount=6 I forgot what I was supposed to remember. Link to comment Share on other sites More sharing options...
BoxerGT2.5 Posted June 1, 2006 Share Posted June 1, 2006 Drop the cans (use WD or PB on hangers to slide them off)....goes in with ease. OBAMA......One Big Ass Mistake America! Link to comment Share on other sites More sharing options...
jsalicru Posted June 1, 2006 Share Posted June 1, 2006 PB Blaster is awesome. Nuff said. "some say, his arms are made of coiled adamantium fibers. And that he tops his cereal with nuts and bolts. All we know is, he's called the Jose." Link to comment Share on other sites More sharing options...
VXCL Posted June 2, 2006 Share Posted June 2, 2006 just buy yourself a compressor and air tools. my 30 gallon craftsman was 300-400. great investment. air tools arent that much either. since i dont use them all the time i dont need real expensive tools like snap on. peace MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
