mwiener2 Posted May 27, 2006 Share Posted May 27, 2006 I've had an exhauSt leak for a while, didn't bother me. The noise was the same since I went stage 2 (almost a year ago) but the smell was getting bad. I had my dad in the car and he couldn't stand it and paid for the new gaskets so I dove right in. Wellllll... I took of the heatshield and look at what I found: http://i13.photobucket.com/albums/a257/mwiener2/IMG_1021.jpg I took it apart and this is what was left: http://i13.photobucket.com/albums/a257/mwiener2/IMG_1024.jpg I guess I probably would have noticed by now, but ya think any of that got sucked into the turbo? Cause any damage? I replaced ALL of the gaskets and now the car is SILENT. So apparently, I've had an exhaust leak the entire time I've been stage 2 and I even changed out a few gaskets 3 weeks after going stage 2. I kinda liked the rumble it made when it was apparently leaking....looks like i might get myself new mufflers..... My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Deer Killer Posted May 27, 2006 Share Posted May 27, 2006 What did it sound like? Link to comment Share on other sites More sharing options...
specinvstr Posted May 27, 2006 Share Posted May 27, 2006 I kinda liked the rumble it made when it was apparently leaking....looks like i might get myself new mufflers..... This is the exact reason I am getting a cbe asap. I lost a bolt from my up to the header and it sounded great. Link to comment Share on other sites More sharing options...
mwiener2 Posted May 27, 2006 Author Share Posted May 27, 2006 What did it sound like? it was all rumbly and mean...like it was gonna kick your ass My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Ridgeracer Posted May 27, 2006 Share Posted May 27, 2006 is that another copper gasket? "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
mwiener2 Posted May 27, 2006 Author Share Posted May 27, 2006 yup, crucial copper gasket Ver 1 all melty My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
KTM 525 Posted May 27, 2006 Share Posted May 27, 2006 Yeah my Crucial cooper gasket did not last long there either. That thing had to be squeeling like a pig under boost. I used 2 OEM gaskets and stacked them. No more leak so far. Your car is dirty underneath LOL. Link to comment Share on other sites More sharing options...
specinvstr Posted May 27, 2006 Share Posted May 27, 2006 Uh oh, that is where my bissing bolt was located. Hope my copper gasket (crucial cer 2) holds up. Link to comment Share on other sites More sharing options...
Mungo Posted May 28, 2006 Share Posted May 28, 2006 OEM gaskets FTW. Link to comment Share on other sites More sharing options...
TSiWRX Posted May 28, 2006 Share Posted May 28, 2006 My gasket is fine, but damn if that isn't the same nut that I lost (lower on flange, manifold-to-UP) that started all of my current "troubles." The problem with me is that I believe, sincerely, that I forgot to re-torque that one after heat-cycling during my initial install, and then *again* forgot to do it after having "fixed" it a couple of weeks ago. This time ( in-part to fix this leak, but more importantly, during my install of new Crucial PP&C'ed manifolds and Injen cross-pipe ), after only ONE heat-cycle, I found both the upper and lower bolt/nut combinations to be loose enough to require re-torquing. You can bet I'm going to hit them again after another couple of heat-cycles - just to be sure. If they continue to give me trouble, I'm going to slip a couple of locking washers on there. These, so far, have been my ONLY problematic set of bolts/nuts. And yes, this type of leak will result in a LGT that sounds pretty much like one that's equipped with an aftermarket exhaust. The only difference is that the sound will be coming from your "engine bay" instead of from behind the vehicle. Still, this is both somewhat surprising (as it is a pre-turbo leak), and can also be rather innocous until more troubles show up in the boost department as it is, shockingly, possible to reach "Stage II"-level boost-targets with even this sizeable pre-turbo leak! ---- mwiener2 - I would wager to think that you're OK. I would think that any exhaust gasses would have "blown" the chunked bits "out." <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
mccorry Posted May 28, 2006 Share Posted May 28, 2006 OEM gaskets FTW. +1 for me..... That gasket (or whats left of it) is amazing! I've never seen one that bad! It had to sound terrible. Link to comment Share on other sites More sharing options...
legacy2005 Posted May 28, 2006 Share Posted May 28, 2006 hmm..might have to jack my car up on tuesday at work and take a look at that flange. just found out today that i have a slight boost leak somewhere cus i now get a whilstle while on boost. Work hard. Play even harder. My Garage Link to comment Share on other sites More sharing options...
mwiener2 Posted May 28, 2006 Author Share Posted May 28, 2006 I tried a new meathod this time. I have that copper spray stuff for putting on gaskets. I sprayed all the bolts with it too. It gets all sticky and gunky and I think it'll help keep the nuts on. I hope. Side note.. I hit target boost 3rd through 5th (18.something PSI) But second tops out at 11psi. I can't remember if 2nd hit higher before or not. I know 2nd shouldn't hit target, but i thought it would hit more like 14 or 15....... My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Deer Killer Posted May 28, 2006 Share Posted May 28, 2006 I put anti-seize on all my bolts and I have had no problems :/ Also I used real exhaust sealant, this stuff hardens with temperature and doesn't break down with temperature. Read the max temperature on the back of that that "copper" gasket crap everyone recommends. It's really a low-temp gasket with some copper in it. Link to comment Share on other sites More sharing options...
mwiener2 Posted May 28, 2006 Author Share Posted May 28, 2006 this isn't the copper paste that everyone keeps talking about....it's an aresol spray http://www.midwayautosupply.com/detailedproductdescription.asp?792 even lists exhasut components as a use edit: just found the MSDS sheet for it...hehe http://www.mightyautoparts.com/pdf/msds/permatex/101h.pdf My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Deer Killer Posted May 28, 2006 Share Posted May 28, 2006 this isn't the copper paste that everyone keeps talking about....it's an aresol spray http://www.midwayautosupply.com/detailedproductdescription.asp?792 even lists exhasut components as a use edit: just found the MSDS sheet for it...hehe http://www.mightyautoparts.com/pdf/msds/permatex/101h.pdf Yeah temperature range -50 to 500 F Major ingredients: Acetone, rubber, resin. My guess is it looks like ash when you take it apart, if it's there at all. Link to comment Share on other sites More sharing options...
Deer Killer Posted May 28, 2006 Share Posted May 28, 2006 the RTV silicone has a better temp range, 700F, but still not high enough. It's frickin silicone. http://www.midwayautosupply.com/detailedproductdescription.asp?2390 What kind of EGT's do NA engines have? Link to comment Share on other sites More sharing options...
mwiener2 Posted May 28, 2006 Author Share Posted May 28, 2006 There was still residue of the stuff on the gaskets that I took off yesterday and that had been on there for something like 14,000 miles....so i guess it does work. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
MDTURBO Posted May 28, 2006 Share Posted May 28, 2006 no liquid gasket seal is good enough, use oem's and call it a day. always use new gaskets when taking pipes off. 2012 Forester XT. Stage 2+ Retired from Racing. I used to build FMIC and more. Link to comment Share on other sites More sharing options...
JuxtaGT Posted May 28, 2006 Share Posted May 28, 2006 When I took my headers and uppipe off, that same Crucial gasket was cracked. Head gaskets look great. Uppipe to turbo looked good. Maybe the new annealed gaskets are better? Link to comment Share on other sites More sharing options...
Deer Killer Posted May 28, 2006 Share Posted May 28, 2006 annealed = softer. Link to comment Share on other sites More sharing options...
coxx Posted May 28, 2006 Share Posted May 28, 2006 OEM gaskets FTW. +1 my copper one's failed pretty quickly & badly. "Barack Obama, mothaf#%@a! Barack Obama! I'm the president...of hittin' the ass!" -this is not a political view it's merely a quote from a hilarious tv show. Link to comment Share on other sites More sharing options...
mwiener2 Posted May 28, 2006 Author Share Posted May 28, 2006 well, this is my last try with the coppers.....maybe Ver. 2 are better cause they're less likely to start a little leak. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
JuxtaGT Posted May 28, 2006 Share Posted May 28, 2006 Well, if they are softer, and possibly more maliable, they'd be less likely to crack/fail/leak? Link to comment Share on other sites More sharing options...
mwiener2 Posted May 28, 2006 Author Share Posted May 28, 2006 being annealed to begin with, you can crank down on them and get them really tight....as opposed to Ver1 which would anneal from the heat of the exhaust and then soften and form leaks. And once a leak forms, the hot gasses blowing by will just eat up the copper. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
