LegacyMUN2k6 Posted May 25, 2006 Share Posted May 25, 2006 http://cgi.ebay.com/ebaymotors/BMW-E46-Angel-Demon-Eyes-DDE-Kit-PRE-WIRED-RED-LED_W0QQcmdZViewItemQQcategoryZ42613QQitemZ8068072381QQrdZ1QQsspagenameZWDVW#ebayphotohosting i was interested in doing a angel eye mod to the headlights using these. Link to comment Share on other sites More sharing options...
HungHing88 Posted May 25, 2006 Share Posted May 25, 2006 it mgiht be kind of hott, man!! what color isyour ride!! Link to comment Share on other sites More sharing options...
LegacyMUN2k6 Posted May 25, 2006 Author Share Posted May 25, 2006 silver Link to comment Share on other sites More sharing options...
froggert Posted May 25, 2006 Share Posted May 25, 2006 ooo.. would those have to be modded to fit our cars? Link to comment Share on other sites More sharing options...
Nsaglibene Posted May 25, 2006 Share Posted May 25, 2006 Illegal also, I belive, as it could be seen as impersonating a cop for having red lights in front. Link to comment Share on other sites More sharing options...
HungHing88 Posted May 25, 2006 Share Posted May 25, 2006 that is ture though, very goo dpoint Nsaglibene Link to comment Share on other sites More sharing options...
LegacyMUN2k6 Posted May 25, 2006 Author Share Posted May 25, 2006 that stinks Link to comment Share on other sites More sharing options...
giotein Posted May 25, 2006 Share Posted May 25, 2006 says that they are for BMW.. therefore they will not fit with out modifying them. my first set of angels came from an M3... in the end.. wasn't worth the time to modify them and what not. Link to comment Share on other sites More sharing options...
Precise Posted May 25, 2006 Share Posted May 25, 2006 i had an e39 bmw before and put a red lens filter to have some 'red' demon eyes. It looked like the car was smokin some weed. i'll see if i can get the pics off my xbox Link to comment Share on other sites More sharing options...
panamajack Posted May 25, 2006 Share Posted May 25, 2006 I think red is OK. Flashing blue light are illegal though. Not 100% on the red though. Link to comment Share on other sites More sharing options...
mechdiff Posted May 25, 2006 Share Posted May 25, 2006 They'd have to be called Devil Eyes. Hmm, weird that they don't have a picture of a car with them installed. I'd like to see how it looks. Link to comment Share on other sites More sharing options...
jerami1981 Posted May 25, 2006 Share Posted May 25, 2006 guessing if they are designed for bimmers they are legal, not too many popo bimmers running around, so i imagine ity was designed for at least semi mass marketing to the general public...i would assume legal Link to comment Share on other sites More sharing options...
AMBIVALENCE Posted May 25, 2006 Share Posted May 25, 2006 someone talk to the seller and get the question answered hmmm. i think it would work if we give the legacy circumference to them to make it. Afterall it's really cheap (look at the gialla ones out there) Link to comment Share on other sites More sharing options...
TSiWRX Posted May 25, 2006 Share Posted May 25, 2006 Custom lengths definitley would work better, but it should not be too much trouble to simply cut -and- re-glue the acrylic "rod" that serves as the lighting conduit in this simple LED-based "Angel Eyes" setup. Note, though, that such LED-based setups will typically not be bright enough to be seen at a distance, nor will they pair well with either our "un-sheilded" high-beams nor, for example, if your LGT has been converted with an HID low-beam setup. While the LED-based units may not be very visible once you get a few feet from the vehicle, please do still note that you should THOROUGHLY research your local ordinances and laws regarding vehicle lighting codes to insure that any BLUE OR RED (the latter with the exception of rear-facing brake lights) lighting - or even AMBER/ORANGE/YELLOW (outside of your turn signals/hazards and low-mounted fog-lights) or GREEN - carry any type of usage restrictions, be it with or without strobing ability. These laws tend to vary quite a bit depending on locale. If you are able to be on-the-road, legally, with such a setup in your local area, still, I would urge you to highly consider wiring in an independent power switch when such colors - especially blue or red - are used. For while you may be operating the vehicle, as-modified, legally on your local roads, this legality may change drastically as soon as you cross your township/city/county/etc. lines! <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
raz-0 Posted May 25, 2006 Share Posted May 25, 2006 At least in NJ anything but white or yellow visible from the front of the car is illegal. Any under car lighting that the lamp can be seen from outside the car is illegal (where it just reflects off the road is up to a court to decide). Blue is preetty much bad all around. Lighted plate rings technically get dinked for obscuring the license plate. Having more than one set of auxillary driving light (law is unclear about mounted, or in use) is also illegal. So undercar neons, those stupid washer sprayer nozzles in anything but white or yellow, that electroluminescent blue knight rioder looking crap, LED valve caps, blue bulbs in clear corners, etc.. all illegal. Some of them they can technically impound your vehicle for if they want. SO yeah.. check your local laws. If a 16 year old thinks it's cool, it's probably illegal. Link to comment Share on other sites More sharing options...
grimbeaver Posted May 25, 2006 Share Posted May 25, 2006 I have a set of purple ones, but not sure how they will fit... from the look of it it looks slightly small. Link to comment Share on other sites More sharing options...
LegacyMUN2k6 Posted May 25, 2006 Author Share Posted May 25, 2006 where did you get them, and how much? Link to comment Share on other sites More sharing options...
SC GT Posted May 25, 2006 Share Posted May 25, 2006 Whoever buys these is just itching to get pulled over by the cops. ... and what the hell is that thing in raz-O's avatar? I've got a neighbor who I hate and I'd like to introduce her to one of those. How difficult are they to house train? Link to comment Share on other sites More sharing options...
panamajack Posted May 25, 2006 Share Posted May 25, 2006 ^ ? wombat? Link to comment Share on other sites More sharing options...
Nsaglibene Posted May 26, 2006 Share Posted May 26, 2006 My friend had red led's as his city lights in his GS and got ticketed for impersonating an officer a couple of times. Link to comment Share on other sites More sharing options...
raz-0 Posted May 26, 2006 Share Posted May 26, 2006 Whoever buys these is just itching to get pulled over by the cops. ... and what the hell is that thing in raz-O's avatar? I've got a neighbor who I hate and I'd like to introduce her to one of those. How difficult are they to house train? It's a hairless cat defending his french fry. I have no idea whose it is, but I figured it'd make a good avatar. Link to comment Share on other sites More sharing options...
Legasee Posted May 27, 2006 Share Posted May 27, 2006 I saw a set of those red Angel eyes on a riced out Accord...looked kindy funky, I wouldn't do it...and ya...Socal popo would be ticket happy if they saw that. In Taiwan now... Link to comment Share on other sites More sharing options...
