Epik Posted May 12, 2006 Share Posted May 12, 2006 i dont know if this is the right place, so here goes....ive been working on cars and trucks for about 9 years now, and my question is,. . . .should there be some oil in the hole with the spark plugs? or is this a seal/pulg problem and needs to get fized. i was told some oil will be ok, but on the S-10 im bulding ive never encountered this. this is the first suby 2001 LGT ive dealt with so please any help/suggestions will help me out, sorry foe the book but i dont kow how else to explain it with out more detalil, ill give you more if you need it to anwser this question...thank you all in advance Link to comment Share on other sites More sharing options...
rao Posted May 12, 2006 Share Posted May 12, 2006 There should none. It could be a bad seal at the valve cover, that is not uncommon on Subaru motors. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Epik Posted May 12, 2006 Author Share Posted May 12, 2006 ****, so if i do the seals over there should be a better seal? thank you much Rao Link to comment Share on other sites More sharing options...
rao Posted May 12, 2006 Share Posted May 12, 2006 ****, so if i do the seals over there should be a better seal? thank you much Rao Could be. There are seals in the valve covers at the plug openings. If those are bad you will get oil in the plug wells. That is the least expensive, least bad explanation for oil in the plug wells. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
pliptheshevanel Posted May 13, 2006 Share Posted May 13, 2006 Same thing happened on mine. It's just the Valve Cover Gasket and Spark Plug seals. Not that hard of a fix, and definately easier on the wallet than alot of fixes. Link to comment Share on other sites More sharing options...
johnAWD Posted May 13, 2006 Share Posted May 13, 2006 There are plug well gaskets under the valve covers. Sounds like yours may be failing. Link to comment Share on other sites More sharing options...
K.G.B. Posted March 17, 2011 Share Posted March 17, 2011 sorry to bring this old thread up but I'm having the same problem. I recently bought an 02 legacy gt wgn with 122000 and while doing the tune-up i found oil in the spark plugs. Can anyone direct me to a link with the walk through for changing the valve gaskets? thanks in advance. Link to comment Share on other sites More sharing options...
subikid90 Posted March 19, 2011 Share Posted March 19, 2011 http://www.rs25.com/forums/f105/t51254-diy-valve-cover-spark-plug-gasket-install.html -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
K.G.B. Posted March 26, 2011 Share Posted March 26, 2011 awesome!!! thanks a lot bro! Link to comment Share on other sites More sharing options...
subikid90 Posted March 31, 2011 Share Posted March 31, 2011 no prob -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
