Guest Posted May 4, 2006 Share Posted May 4, 2006 Are there any pillar gauge pods available for LGT? Down the road I'd like to install a turbo boost gauge, and would prefer it on the pillar rather than elsewhere. Link to comment Share on other sites More sharing options...
ToyMachineAR Posted May 4, 2006 Share Posted May 4, 2006 I thought about getting one custom made... I thought about buying a "bolt on" pillar mount and taking the stock pillar and that to an interior shop here in town... tell them to mount it then upholster it in matching cloth. Maybe a little pricey for most people's taste, but when you want it done your way, and RIGHT(!)... it may cost. Jeff Link to comment Share on other sites More sharing options...
scans007 Posted May 4, 2006 Share Posted May 4, 2006 The reason why no one has done this yet is we have Airbags that deploy outta our pillars....if the bags go off it could knock you out cold So IF you do, make sure you disable the air bags over there (if it's possible) Link to comment Share on other sites More sharing options...
Billy Dagwood Posted May 4, 2006 Share Posted May 4, 2006 err .. airbags. dangerous. there's always the avo pod, though, which is low enough to be ok Link to comment Share on other sites More sharing options...
Guest Posted May 5, 2006 Share Posted May 5, 2006 The reason why no one has done this yet is we have Airbags that deploy outta our pillars....if the bags go off it could knock you out cold So IF you do, make sure you disable the air bags over there (if it's possible) Dumb me I didn't realize that. I am picking up my Subbie this Saturday, didn't have time yet to look carefully around it inside... Link to comment Share on other sites More sharing options...
panamajack Posted May 5, 2006 Share Posted May 5, 2006 Do they have the side airbags in Japan? I dont think they do. Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted May 5, 2006 Share Posted May 5, 2006 I think mweiner just put a screw in a mounting bracket and put it in the pillar. Link to comment Share on other sites More sharing options...
subastyle Posted May 5, 2006 Share Posted May 5, 2006 i dont know if you guys have had your pillar apart but the airbag is way up in the top of the pillar,,so you could put a pod on there i think with out getting knocked the funked out Link to comment Share on other sites More sharing options...
TSiWRX Posted May 5, 2006 Share Posted May 5, 2006 ^ +1 - there are several post-crash photos floating around here on the Forums that confirms the high-up location of the front curtain bags. As long as you keep things down-low, current consensus is that you should be just fine. <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
