Repsak Posted December 12, 2006 Share Posted December 12, 2006 well i put my stock shifter back in and it sounds A LOT quieter. However Going from 3rd to 2nd is still noticable. Im just wondering if this was like this before or not. Gonna call Subaru tommorow and see what they say.... Link to comment Share on other sites More sharing options...
itsme Posted December 12, 2006 Share Posted December 12, 2006 well i put my stock shifter back in and it sounds A LOT quieter. However Going from 3rd to 2nd is still noticable. Im just wondering if this was like this before or not. Gonna call Subaru tommorow and see what they say.... That's what I would do. Just play dumb. Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
Repsak Posted December 12, 2006 Share Posted December 12, 2006 indeed this is why i always keep parts, never know when one of themn can save you a few grand Link to comment Share on other sites More sharing options...
undert0e Posted December 12, 2006 Share Posted December 12, 2006 When I removed my shifter and chopped it I noticed that there was a noise comming from below the shifter similar to the sound that you guys are talking about. I took the shifter back out and filled the mounting hole with grease and the sound went away.. maybe just my car though. Link to comment Share on other sites More sharing options...
Repsak Posted December 12, 2006 Share Posted December 12, 2006 will have to try that... thanks Link to comment Share on other sites More sharing options...
G.T.Subie Posted February 1, 2007 Share Posted February 1, 2007 Did anyone sounds get resolved? I just had this pop up and I have had my Cobb STS in for over a year. Denial is your best friend Link to comment Share on other sites More sharing options...
Repsak Posted February 2, 2007 Share Posted February 2, 2007 take it out, grease the crap out of it. Mine is a lot quieter now, but I can still hear it every now and then. Link to comment Share on other sites More sharing options...
G.T.Subie Posted February 2, 2007 Share Posted February 2, 2007 What type of grease did you use? Thanks. Denial is your best friend Link to comment Share on other sites More sharing options...
mickeyd2005 Posted February 2, 2007 Share Posted February 2, 2007 Yeah, I would like to know what type of grease too. Everyone seems to "reuse" the old grease. Seems ghetto to me. I would really like to know what kind of grease is good... otherwise, I might use the grease that I use for my battery posts. BTW, did you guys compare the cobb STS ball to the stock ball. The cobb WRX STS has a smaller ball size. Link to comment Share on other sites More sharing options...
G.T.Subie Posted February 2, 2007 Share Posted February 2, 2007 Didn't notice ball size:lol: . Denial is your best friend Link to comment Share on other sites More sharing options...
mickeyd2005 Posted February 2, 2007 Share Posted February 2, 2007 LGT balls are bigger than WRX balls. You should know that. Link to comment Share on other sites More sharing options...
captainmorgan Posted February 2, 2007 Share Posted February 2, 2007 I did something similar, and just packed the cup full of wheel bearing grease (its all I had laying around). Noise went away and everything felt great. Only now, I'm starting to get a clunk on first and second when starting with the tranny under slight load (like starting at a stoplight that is on an upward hill). You can feel it hit through the shifter as well as hear it. Link to comment Share on other sites More sharing options...
Repsak Posted February 3, 2007 Share Posted February 3, 2007 anytype of thick grease should work. Something you scoop with your fingers and doesnt come off would be fine. Ill get the name of the product i use at work on monday. Link to comment Share on other sites More sharing options...
SSpeed Posted October 20, 2007 Share Posted October 20, 2007 Did this get resolved with just grease? I did the KartBoy short shifter too about 2 weeks ago and love it, it feels like a real performance car now... BUUTTTT, last night coming home, on moderate acceleration shifts, I get an occasional "buzz" between gears.. not a whine, not transmission noise, the shifter buzzing pretty much... When I initially did the shifter I reused the old grease, I don't think that was enough.. I pulled it out today, cleaned all the grease off, and repacked it with a ton of white lithium grease... I think for the shifter, the thicker grease you can use the better.... it was so intermittent I'll have to see if that solved it... Link to comment Share on other sites More sharing options...
itsme Posted October 20, 2007 Share Posted October 20, 2007 Did this get resolved with just grease? I did the KartBoy short shifter too about 2 weeks ago and love it, it feels like a real performance car now... BUUTTTT, last night coming home, on moderate acceleration shifts, I get an occasional "buzz" between gears.. not a whine, not transmission noise, the shifter buzzing pretty much... When I initially did the shifter I reused the old grease, I don't think that was enough.. I pulled it out today, cleaned all the grease off, and repacked it with a ton of white lithium grease... I think for the shifter, the thicker grease you can use the better.... it was so intermittent I'll have to see if that solved it... DId you install the Kartboy rear bushing? If so that maybe causing the buzz. Go back to stock and see what happens. The stock will go back in easier if you put alittle dish soap on it. Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
SSpeed Posted October 21, 2007 Share Posted October 21, 2007 DId you install the Kartboy rear bushing? If so that maybe causing the buzz. Go back to stock and see what happens. The stock will go back in easier if you put alittle dish soap on it. I have just the shifter installed... Link to comment Share on other sites More sharing options...
dshap13 Posted October 22, 2007 Share Posted October 22, 2007 I have this same exact problem. Just have the shifter installed as well. Was fine for the first year the shifter was installed, and just over the past 3 months, the same exact sound mentioned here is heard. I too, thought it may have been the shift nob, so I drove the car without the nob attached to the gear lever, and still heard the problem. Brought the car into the dealer for them to check it out, and they thought it was a tranny problem. They basically gave me a whole new tranny under warranty, and the sound still exists. They tried to put some sound deadening material around the shifter, but the sound is still present. They assured me that the tranny was fine and everything is working correctly, so I'm living with it. Sometimes it's worse than others. Seems like the sound is dependant upon RPM's. I shift faster now in and out of 4th and 5th so I don't have to hear it. I sort of chalked it up to NVH. Link to comment Share on other sites More sharing options...
Bill_Cosbys_Nightmare Posted October 23, 2007 Share Posted October 23, 2007 I noticed this as well about a week after the cobb STS install. Only seems to make a noise when shifting between 1st and 2nd. Being paranoid about my tranny I brought this to the dealer and they said they could hear it a little as well but said everything looked normal... they kind of hinted to the fact that I had an aftermarket sts in there and i got the feeling that if something went wrong with my tranny they'd use that card to get out of replacing it under warranty. Did you get the new tranny with that sts installed or did you take it out and put the stock in before bringing it to the dealer? I still have mine so I could do that, but it's a pain in the butt if i don't have to. I've had the sts installed now for about 5 months and i can maybe say the noise has gotten a little louder. It sounds kind of like the synchros to me, but I'm no expert. My biggest concern was that I'm stressing the synchros and one day they're going to just wear out. Link to comment Share on other sites More sharing options...
dshap13 Posted October 23, 2007 Share Posted October 23, 2007 My sts was installed when I brought it to the dealer. They didn't say anything about it prior to throwing parts at the problem. Not even sure they noticied it was aftermarket vs. sti. Link to comment Share on other sites More sharing options...
