panamajack Posted April 3, 2006 Share Posted April 3, 2006 What bulbs should I get to replace my stocks? I want my fog lights to be very bright (ie rally). I do alot of driving at night on dark roads. I want something more powerfull. The stock bulbs are very weak. Link to comment Share on other sites More sharing options...
TSiWRX Posted April 3, 2006 Share Posted April 3, 2006 ^ You'd do well to simply graft-on aftermarket driving lights. While you can get higher-wattage bulbs for the stock fog application (check the "Bulb Applications" thread), the factory optics assembly is optimized for a true "fog" pattern dispersion, and even when re-aimed, will prove far less than optimal for your lighting needs. Even if you are satisfied with re-aiming of the factory fogs + higher wattage bulbs at this location, you should know that this will still effectively completely flood your foreground, and while you may think you're "seeing better due to brighter lights," you're actually only seeing the areas closest to your front bumper in greater light, and thus are effectively ruining your distance night-vision. Per your desires, a set of properly designed and aimed aftermarket driving lights will best fit your needs. <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
team23jordan Posted April 3, 2006 Share Posted April 3, 2006 search please!! Perrin BIG maf intake Perrin Turbo Inlet HKS SSQV BOV Megan Racing header with UP (ceramic coated) HKS DP (WRX) DMH E-cutout Custom 3" catback UTEC Link to comment Share on other sites More sharing options...
