mbanks21 Posted April 2, 2006 Share Posted April 2, 2006 Hey guys, Im looking to purchase a 05/06 LGT and just had a quick question about performance options. From what Ive gathered browsing the forums its pretty much: CAI, UP, DP, Catback, ECU flash. Do I need a new MP or just get a DP that replaces the MP? Also, what kind of HP are we looking at for the above mentioned mods? Im coming from a 98 M3 vert with ~290HP but I need something with 4 doors and the LGT is a real sleeper. Link to comment Share on other sites More sharing options...
RuskiTrombone Posted April 2, 2006 Share Posted April 2, 2006 Welcome to the boards. CAI will not be necessary. Full turboback exhaust which includes UP and DP coupled with a stage two reflash through the Cobb Accessport will net you about 340 to the crank. There are other gains to be made via pulleys and a TMIC or just upgrade the turbo to let's say a G20 turbo. Anything and everything I had mentioned above can also be easily searched on this site as there are hundreds of threads just like this one. Good luck with the purchase. Link to comment Share on other sites More sharing options...
rallispec Posted April 2, 2006 Share Posted April 2, 2006 first step = cobb accesssport (flash to stage 1 = $645) second step = crucial shorty downpipe and used STi catless uppipe = $499 (flash to AP stage 2) third step = TDC stage 2 map = $150 fourth step = Pirelli Pzero Nero all season tires on stock wheels = $500 fifth step = Boral (SPT) cat-back exhuast = $700 sixth step = sh!t eating grin on your face = priceless. Link to comment Share on other sites More sharing options...
mudfoot Posted April 2, 2006 Share Posted April 2, 2006 first step = cobb accesssport (flash to stage 1 = $645) second step = crucial shorty downpipe and used STi catless uppipe = $499 (flash to AP stage 2) third step = TDC stage 2 map = $150 fourth step = Pirelli Pzero Nero all season tires on stock wheels = $500 fifth step = Boral (SPT) cat-back exhuast = $700 sixth step = sh!t eating grin on your face = priceless. you can purchase the AP through Jon/TDC for like 50 more with a map i believe... around 700 total... Got Torque ? Link to comment Share on other sites More sharing options...
jim malach Posted April 2, 2006 Share Posted April 2, 2006 First thing you should get are brakes they suck really they do just ask everybody come on the brakes just are bad that what I would do ps and your coming from an m3 my friend has an m3 and he said my brakes suck might just be me Link to comment Share on other sites More sharing options...
tintinet Posted April 2, 2006 Share Posted April 2, 2006 Many also alter suspension, either new springs, coil-overs, and/or stiffer sways, etc..... Link to comment Share on other sites More sharing options...
RuskiTrombone Posted April 2, 2006 Share Posted April 2, 2006 I did the same thing I did with my celica. I did looks first, then speed. I can never get it right. Link to comment Share on other sites More sharing options...
EL PAALO Posted April 2, 2006 Share Posted April 2, 2006 First thing you should get are brakes they suck really they do just ask everybody come on the brakes just are bad that what I would do ps and your coming from an m3 my friend has an m3 and he said my brakes suck might just be me the brakes don't feel great, but they work quite well. lines and pads should make it excellent. Link to comment Share on other sites More sharing options...
mbanks21 Posted April 2, 2006 Author Share Posted April 2, 2006 So I can get the UP, DP, and stage 2 sw w/ TDC at the same time. Whats the benefit of the TDC? Link to comment Share on other sites More sharing options...
mudfoot Posted April 3, 2006 Share Posted April 3, 2006 {qoute} mbanks21....Whats the benifit of the TDC? {quote} he makes your car go faster Got Torque ? Link to comment Share on other sites More sharing options...
rallispec Posted April 3, 2006 Share Posted April 3, 2006 So I can get the UP, DP, and stage 2 sw w/ TDC at the same time. Whats the benefit of the TDC? just a more aggressive map over the stock COBB stage 2 map. (higher boost, timing, etc..) Link to comment Share on other sites More sharing options...
tintinet Posted April 3, 2006 Share Posted April 3, 2006 And, if stage 1 experience translates, a smoother tune. Link to comment Share on other sites More sharing options...
rfd425 Posted April 4, 2006 Share Posted April 4, 2006 If you're coming from an E36 M3, you're going to want to do some suspension mods. You can do just springs fairly cheaply, or you can do struts and springs, or coilovers, for more money. One option is to get Spec B Bilstein struts, and STi pink or swift springs. Total cost should be in the $1,800 range, but you can reduce that if you can source some JDM Bilstein struts (either Spec B or JDM GT). With Stage 2 power, a brake upgrade is probably a good idea as well. Link to comment Share on other sites More sharing options...
blklgt05 Posted April 4, 2006 Share Posted April 4, 2006 most people who are looking for serious performance spend 100+hrs tuning and have 10+ different performance map for different setting and temp. So just so you know, even if you get stage 2 on cobb ap with up/dp/cbe.. you probably wont be able to optimize their power fully. mod journal Link to comment Share on other sites More sharing options...
