225/50R17 - would it fit onto a 2005 SpecB
AndreyLegacy
Hi,
I have a SpecB in Russia, and getting good Winter tyres in 215/45R17
is a bit of a prob.
I bought the 205/50R17 - they are good, but I'd prefer the car ground clearance to be a bit higher.
So question is - would the 225/50R17 fit in?
I did not bother to try, but did anyone ever tried it?
What is the size of the original tire? 215/45-18? (that is what the US spec B uses...)
The 225/50-17 you mention is VERY close to that. Using a tire calculator, it estimated 7 Revolutions fewer per mile, and the 17" would have roughly 3/10ths of an inch more diameter (.7 inches more circumference.)
http://www.miata.net/garage/tirecalc.html
I would think that would be an excellent size for winter tires, with a taller more flexible sidewall for snow and ice grip, and better impact protection, and no sacrifice in ride height, and negligible speedometer error.
I'm currently running 225/45/18s on 18 X 7.5 rims with a +50 offset,
GT Bilstein struts, and Wangan springs. The diameter of my tires is .1" bigger than yours, and I get no rubbing. You should be fine.
