djjuice Posted March 30, 2006 Share Posted March 30, 2006 I'm looking to get new wheels & summer tires for my RBP 06 LGT. I've never bought wheels before, but thanks to the all the info on here (thanks Xenonk) I've learned a lot about what to look for. Here are some questions for y'all: 1. Do most people buy wheels sight-unseen? Or do you go to some kinda place that has a showroom, see the wheel you want to get in person *before* you buy? 2. Anyone have Advan Model 5 or Kreuzer V? These are near the top of my list. Any pics would be appreciated. 3. Our stockers are 215 width tires on 7" wide wheels. Besides the change in circumference, what's the downside to going to 225 width tires on the same 7" wheel? Many thanks to all. -Jon Link to comment Share on other sites More sharing options...
Xenonk Posted March 30, 2006 Share Posted March 30, 2006 1. website or at a race/show event 2. Yes, a few people on http://www.nasioc.com has them, you just have to do a search 3. not much at all, some people cant even tell the difference between the two when driving. Keefe Link to comment Share on other sites More sharing options...
ilh Posted March 30, 2006 Share Posted March 30, 2006 3. not much at all, some people cant even tell the difference between the two when driving.Is there any real upside [225 v. 215]? Wider tires doesn't mean bigger contact patch, just wider, so better for cornering but maybe worse for braking? --Lee Link to comment Share on other sites More sharing options...
rexster Posted March 31, 2006 Share Posted March 31, 2006 Is there any real upside [225 v. 215]? Wider tires doesn't mean bigger contact patch, just wider, so better for cornering but maybe worse for braking? --Lee acually, wider does mean bigger contact patch. area = length x width but the tire compound is even more important than adding a little more width. Link to comment Share on other sites More sharing options...
ilh Posted March 31, 2006 Share Posted March 31, 2006 To a first order approximation, I always thought that area*pressure = weight on tire. The air pressure inside the tires pushing down on the contact patches is what is holding up the car. (Note I said approximation. Obviously, the stiffer the rubber, the less it holds. You can certainly see that decreasing pressure increases contact patch, which is why you decrease pressure when driving on a beach, etc.) Keep the weight on the tire and inflation pressure constant, and the area will remain relatively constant. 215/45 and 225/45 are probably so close in construction (rubber stiffness), that I seriously doubt you will see much difference in total contact patch area between the two. The biggest change will be in the shape. For example, last post here. --Lee Link to comment Share on other sites More sharing options...
Xenonk Posted March 31, 2006 Share Posted March 31, 2006 Is there any real upside [225 v. 215]? Wider tires doesn't mean bigger contact patch, just wider, so better for cornering but maybe worse for braking? --Lee I dont see why it would be worse for braking, the tire goes under compression and the tires expand up front and creates a wider contact patch.. Keefe Link to comment Share on other sites More sharing options...
EL PAALO Posted April 1, 2006 Share Posted April 1, 2006 contact patch shape changes according to wheel width as well so it also depends on that. Link to comment Share on other sites More sharing options...
