jim1969 Posted March 29, 2006 Share Posted March 29, 2006 Has anyone tried to adapt this to fit a 60mm gauge (i.e. dremel it out)? I'm surprised AVO hasn't released a 60mm version. Link to comment Share on other sites More sharing options...
joeb-z Posted March 29, 2006 Share Posted March 29, 2006 I think it would get pretty tight to fit the larger guage. Another question. Has anyone figured out a good mounting method for the AVO pod? Beware the black adhesive supplied. It doesn't adhere and it makes a mess of the pillar. Link to comment Share on other sites More sharing options...
scans007 Posted March 29, 2006 Share Posted March 29, 2006 I made a 2sided tape "base" cleaned the dashboard stuck the tape down, sat the gauge pod right over it...never moved....after a while the tape came a lil loose.....pulled if off, did it again and pulled the wires and tube tighter in the back down the pillar, never had a prob again... Def a "hack" solution though Link to comment Share on other sites More sharing options...
Legacy05 Posted March 29, 2006 Share Posted March 29, 2006 I made a 2sided tape "base" cleaned the dashboard stuck the tape down, sat the gauge pod right over it...never moved....after a while the tape came a lil loose.....pulled if off, did it again and pulled the wires and tube tighter in the back down the pillar, never had a prob again... Def a "hack" solution though I did something similar, I took all the black crap off the pod, hacked up a dvd case and made a new base and glued it to the bottom of the gauge pod. Cleaned off the dash really well and used 3m double sided sticky tape. So far so go, if it comes loose again I will just re-tape and I don't have to worry about it messing my a-pillar. Link to comment Share on other sites More sharing options...
