BLACKonBLACK Limited Posted March 28, 2006 Share Posted March 28, 2006 I just did my 5k oil change and after the change as the car was idling i was checkin out my exhuast tips i noticed a black watery/oily substance in the tip, i whipped it off then check 5 min later (still iding) and there was some more. It wasn't dripping or pouring out of the tip, it would just sit at the very end of the tip. Is this normal? Link to comment Share on other sites More sharing options...
Penguin Posted March 28, 2006 Share Posted March 28, 2006 No this is not normal, you may have a bad case of oil consumption. Does the car tick slightly at idle? If so then you are not getting proper lubrication to the valve gear and are going to be burning the oil that does get up there because it is getting too hot. Take the car to the dealer immediately and ask them to take a look, I would hate to see more damage done to the motor. Eventually the heat will ruin the temper on the cams and valve stems and you will lunch the valve gear. Tell the dealer to check the RE92's, they are most likely the cause of the lubrication problem. Just kidding, this is normal water vapor in the exhaust mixing with the carbon from combustion. Relax. Link to comment Share on other sites More sharing options...
eamiller Posted March 28, 2006 Share Posted March 28, 2006 There is a lot of carbon buildup on LGTs due to the very rich state they run in when at or near full throttle. When it is cool out and the engine hasn't warmed up, you'll get a lot of condensation in the exhaust which will mix with the carbon and make a nice black liquid. In short: it's normal. Link to comment Share on other sites More sharing options...
melayout Posted March 28, 2006 Share Posted March 28, 2006 Collect the liquid and send it in for oil analysis. Penguin, siriusly I keed I keeed Link to comment Share on other sites More sharing options...
coxx Posted March 28, 2006 Share Posted March 28, 2006 Mine does it too. Not a problem "Barack Obama, mothaf#%@a! Barack Obama! I'm the president...of hittin' the ass!" -this is not a political view it's merely a quote from a hilarious tv show. Link to comment Share on other sites More sharing options...
rallispec Posted March 28, 2006 Share Posted March 28, 2006 No this is not normal, you may have a bad case of oil consumption. Does the car tick slightly at idle? If so then you are not getting proper lubrication to the valve gear and are going to be burning the oil that does get up there because it is getting too hot. Take the car to the dealer immediately and ask them to take a look, I would hate to see more damage done to the motor. Eventually the heat will ruin the temper on the cams and valve stems and you will lunch the valve gear. Tell the dealer to check the RE92's, they are most likely the cause of the lubrication problem. HAHAHAHAHA Link to comment Share on other sites More sharing options...
mwiener2 Posted March 28, 2006 Share Posted March 28, 2006 All turbo cars do this.....well..ALL cars drip water out the pipes...turbos are just dirtier worse at idle casue by the time the gases reach the tailpipe they cooled enough for the water vapor to condense My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
BLACKonBLACK Limited Posted March 28, 2006 Author Share Posted March 28, 2006 No this is not normal, you may have a bad case of oil consumption. Does the car tick slightly at idle? If so then you are not getting proper lubrication to the valve gear and are going to be burning the oil that does get up there because it is getting too hot. Take the car to the dealer immediately and ask them to take a look, I would hate to see more damage done to the motor. Eventually the heat will ruin the temper on the cams and valve stems and you will lunch the valve gear. Tell the dealer to check the RE92's, they are most likely the cause of the lubrication problem. Just kidding, this is normal water vapor in the exhaust mixing with the carbon from combustion. Relax. haha ass my stomach just dropped Link to comment Share on other sites More sharing options...
godwhomismike Posted March 28, 2006 Share Posted March 28, 2006 Sounds like your car sharted Link to comment Share on other sites More sharing options...
Penguin Posted March 28, 2006 Share Posted March 28, 2006 haha ass my stomach just dropped Hey, I couldn't resist. Anytime I can bash the RE92's, and get someone worried I have to fight the devil on my shoulder to not do it. On a side note, I occasionaly clean the exhast tips on the car to be rid of the black grime. Soap and water works pretty well, and if you want to give them a good polishing, Flitz works really well. Link to comment Share on other sites More sharing options...
Beanboy Posted March 28, 2006 Share Posted March 28, 2006 I like my tips dirty. -B http://www.standardshift.com Link to comment Share on other sites More sharing options...
Penguin Posted March 28, 2006 Share Posted March 28, 2006 I like my tips dirty. Maybe I should try that instead of cleaning them ever again. If I could figure out a way to get that really cool black soot all over the rear bumper I would try that too. Dirty tips and soot all over the bumper are a sure sign of POWER!! Link to comment Share on other sites More sharing options...
mwiener2 Posted March 28, 2006 Share Posted March 28, 2006 Dirty tips and soot all over the bumper are a sure sign of POWER!! No, A slightly melted bumper from a $200 body kit with black soot all over it and cutouts for dual tips but only having a single pipe is a sure sign of P0w3r!!! OB hidden tips FTW!!! My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
AWD_Rules3830 Posted March 29, 2006 Share Posted March 29, 2006 No this is not normal, you may have a bad case of oil consumption. Does the car tick slightly at idle? If so then you are not getting proper lubrication to the valve gear and are going to be burning the oil that does get up there because it is getting too hot. Take the car to the dealer immediately and ask them to take a look, I would hate to see more damage done to the motor. Eventually the heat will ruin the temper on the cams and valve stems and you will lunch the valve gear. Tell the dealer to check the RE92's, they are most likely the cause of the lubrication problem. Just kidding, this is normal water vapor in the exhaust mixing with the carbon from combustion. Relax. you really hate these tires ... HAHAHA LMAO I love my car ... basically. Link to comment Share on other sites More sharing options...
red beast Posted March 29, 2006 Share Posted March 29, 2006 your car is going to blow up. Link to comment Share on other sites More sharing options...
scans007 Posted March 29, 2006 Share Posted March 29, 2006 You should've seen my car on the dyno a few weeks ago, it was spitting that stuff out like it was getting sick.......have someone sit in your car and rev it hard and it will spit at you Link to comment Share on other sites More sharing options...
