redderthanafeut Posted March 27, 2006 Share Posted March 27, 2006 Hey all- 1st. I promise I searched but just can't find any info on a 2000 Outback. I just need to know a couple of things... 1. I need to get the dash off because I want to install an LOC from the front speaker outputs. How do I get this off? 2. Where can I find a wire diagram for my car? The rest is pretty much done, just need to install the LOC and get a tap from the remote wire too. I've attached a picture of my dash. Thanks! Link to comment Share on other sites More sharing options...
leggtnut Posted March 27, 2006 Share Posted March 27, 2006 The dash comes off farily easily. I don't have pics from when I had the baja, but it goes like this: - pry the trim piece from around the shifter out (pups up then toward the back) - take out the ash tray - un screw the 2 (bleaping) screws with a 90 degree philips head driver - the trim around the HVAC/HU will pop off from the bottom up - remove screws (2 or 4 don't remember) to remove the HVAC/HU from the car (the HVAC cables are short) - remove the screws from the HVAC on the bracket - pull out the HU more and disconnect cables Now you have the HU in hand. Hope this helps. Ben (2014 Outback SAP w/ eyesite, 2014 Tribeca Limited, 2006 LGT limited sedan) Subaru Ambassador PNW Link to comment Share on other sites More sharing options...
redderthanafeut Posted March 28, 2006 Author Share Posted March 28, 2006 Thanks for the reply! Yes, I think that makes sense. I'd gotten the shifter piece off but wasn't sure where to go from there.. I guess I should ask too, is there an easier way to tap into the speaker wires and remote wire without taking the deck out? I know I could probably get the remote from the Subaru subwoofer harness that's under the seat (where I put my amp conveniently) but I can't use the speaker wires from that because I want stereo feeding my amp... Any ideas? Link to comment Share on other sites More sharing options...
