Irrational Exuberance Posted March 27, 2006 Share Posted March 27, 2006 just got my 05 about a week ago, and was using defrost this morning with the radio on and it completely scrambled the FM signal. does it on all stations do varying degrees from complete static to "driving thruogh the mountains between BumF*ck and PurtyMouth" static with intermitant sound... any ideas? its going in tuesday to get an alarm installed, i guess i can raise a stink then.... *edit* rear defroster, in case anyone wondered "i like my women the way i like terrorists... ...screaming gods name and ready to explode." http://img255.imageshack.us/img255/5479/troy3nu5.jpg Link to comment Share on other sites More sharing options...
05 GT LTD Owner Posted March 27, 2006 Share Posted March 27, 2006 Same happened to me when my car was brand new. You need to have the rear windshield replaced. Link to comment Share on other sites More sharing options...
Irrational Exuberance Posted March 27, 2006 Author Share Posted March 27, 2006 Same happened to me when my car was brand new. You need to have the rear windshield replaced. covered with warranty? god i hope so, thats some $ id rather put into RSB/FSB "i like my women the way i like terrorists... ...screaming gods name and ready to explode." http://img255.imageshack.us/img255/5479/troy3nu5.jpg Link to comment Share on other sites More sharing options...
croll326 Posted June 8, 2007 Share Posted June 8, 2007 Need a new rear window. $330 from the dealer. They are trying to deny my replacement but I have a call in with SOA and I think they will make the dealer replace the window. Link to comment Share on other sites More sharing options...
TPLGT Posted June 8, 2007 Share Posted June 8, 2007 I know lots of people have had problems w/ interference if the window is tinted..I know I do.....check that out. Rehab is for quitters. Link to comment Share on other sites More sharing options...
Mindspin311 Posted February 8, 2010 Share Posted February 8, 2010 Experienced this issue this morning. Had a lot of frost on the rear glass, it is tinted as well. I also experience this sometimes when I plug my cellphone in on the cigarette charger. Link to comment Share on other sites More sharing options...
F-WDC Spec B Posted February 8, 2010 Share Posted February 8, 2010 I have it too. I thought i crossed some wires when i installed my amp. good to know im not alone. Im going to try to isolate the ant wire and shield it from the rear defogger wire. to bad they are both on the rear glass thou. Link to comment Share on other sites More sharing options...
FlatChris Posted April 3, 2010 Share Posted April 3, 2010 I've read there is a TSB that covers this - one possibility is that there is one or more small breaks in the wires of the defroster grid. These breaks are areas of high electrical resistance which in turns generates an electrical field that is being picked up by the antenna. It can be fixed with a new window or by finding and repairing the breaks in the grid. The bulletin describes using a small hand held radio with an antenna - with the rear defrost on, pass the antenna slowly around the grid until the station is scrambled, then look closely at that spot for a cut or nick in the grid. Use a defrost wire repair kit to fix. Link to comment Share on other sites More sharing options...
Mindspin311 Posted April 3, 2010 Share Posted April 3, 2010 Can you link to the TSB? Link to comment Share on other sites More sharing options...
FlatChris Posted April 4, 2010 Share Posted April 4, 2010 I think this is the one: Radio Static When Rear Window Defogger Is On Service Bulletin #15-126-07 http://techinfo.subaru.com/html/displayPDFDesc.jsp?doc_id=219483 Link to comment Share on other sites More sharing options...
Mindspin311 Posted April 4, 2010 Share Posted April 4, 2010 Thanks! Link to comment Share on other sites More sharing options...
