Deer Killer Posted March 26, 2006 Share Posted March 26, 2006 Not even installed yet, but just shaking as it rattles, I hope that's not going to be very annoying over bumps/rough roads. Is it just mine or has anyone else noticed this? Unfortunately the costmetic metallic ring is also crimped shut, so there goes me opening it without make it look like crap Link to comment Share on other sites More sharing options...
johnAWD Posted March 26, 2006 Share Posted March 26, 2006 I'm pretty disappointed with mine, to be honest. The needle acts like there's no lubrication, so when it moves, it's not smooth. The cosmetic ring on mine was dented when it arrived, and since I've not done so yet, I may leave the seller negative feedback. Esp since I paid $25 in 'shipping & handling', but it took 10 days for the gauge to get to me in Colorado from California. FWIW, no rattle in mine. Link to comment Share on other sites More sharing options...
Deer Killer Posted March 27, 2006 Author Share Posted March 27, 2006 er.. well I got mine in 4 days accross the country so I can't complain about that.. hmm.. no rattle after you put it in, or did you actually check? Link to comment Share on other sites More sharing options...
johnAWD Posted March 27, 2006 Share Posted March 27, 2006 There was no rattle in mine when it arrived. Link to comment Share on other sites More sharing options...
mccorry Posted March 27, 2006 Share Posted March 27, 2006 No rattle... and I pulled mine apart to zero the needle.... it can be done. Just a few small flat blade screwdrivers and work your way around the back edge of the crimp.... eventually, it will pull off. Link to comment Share on other sites More sharing options...
Deer Killer Posted March 27, 2006 Author Share Posted March 27, 2006 Ok I did it, not that pretty but I suppose you won't see it when it's mounted. The part that's loose is the needle itself. There's absolutely no way to tighten it except to bend down the back plate that's the rear "bearing"... ugh. Also my confidence in it's accuracy is very low after seeing what's inside We shall see. johnAWD: I bet yours doesn't work right for the opposite reason, that plate is too tight. Link to comment Share on other sites More sharing options...
Deer Killer Posted March 30, 2006 Author Share Posted March 30, 2006 Ugh (update): I fixed the rattling with graphite and hot glue.. FYI mine had no lubrication at all. yeah.. well.. As long as it's accurate, which I intend to test in some manner I have yet to determine. Link to comment Share on other sites More sharing options...
