Project84 Posted February 27, 2006 Share Posted February 27, 2006 I joined this site basically because I bought a wrecked 1997 LGT and i've needed helpful info putting it back together and learning some tech stuff... here's where im at now: THE CAR WONT START. Battery is fine, cables are fine.... starter was taken off and autozone checked it, its fine... all fuses look to be okay.... what am I missing? Is it something to do w/ the security system? We tried holding the button on the underside of the dash like the sticker on the core support says... nothing happened. When we turn the key, the starter doesnt even click or engage... so is it an ignition problem? someone surely has had this problem before or has an educated suggestion that would help out..?? I'd appreciate any info VERY much! Thanks, John Link to comment Share on other sites More sharing options...
Penguin Posted February 27, 2006 Share Posted February 27, 2006 Bad solenoid. Link to comment Share on other sites More sharing options...
Project84 Posted February 28, 2006 Author Share Posted February 28, 2006 ttt need all the ideas i can get Link to comment Share on other sites More sharing options...
melayout Posted February 28, 2006 Share Posted February 28, 2006 Try NASIOC.com I keed I keeed Link to comment Share on other sites More sharing options...
Aczwild Posted February 28, 2006 Share Posted February 28, 2006 manual or automatic? JDM'd All to hell Thanks Jimmy @ Hkc-Speed.com! RIP Coxx & Thanks Link to comment Share on other sites More sharing options...
Project84 Posted March 1, 2006 Author Share Posted March 1, 2006 automatic Link to comment Share on other sites More sharing options...
Aczwild Posted March 1, 2006 Share Posted March 1, 2006 The parking gear might not be correctly inplace on the trans excpecially since the car took a whack JDM'd All to hell Thanks Jimmy @ Hkc-Speed.com! RIP Coxx & Thanks Link to comment Share on other sites More sharing options...
Project84 Posted March 1, 2006 Author Share Posted March 1, 2006 but its been started plenty of times prior to this. what happened last that i remember was we were taking the battery out to have it charged and when unthreading the positive connection we grounded the wrench out on the belt housing on top the accessories and after that it just wouldnt start.... all fuses are fine though. we're dumbfounded Link to comment Share on other sites More sharing options...
Aczwild Posted March 1, 2006 Share Posted March 1, 2006 Hmm you got me too then I guess the next thing to go over since you checked the fuses in the engine bay would be to check out the solenoid, jeeze, somethin got fried JDM'd All to hell Thanks Jimmy @ Hkc-Speed.com! RIP Coxx & Thanks Link to comment Share on other sites More sharing options...
impostor Posted March 2, 2006 Share Posted March 2, 2006 The SVX had an issue with the starter interrupt relay sticking. Ive seen it happen a few times on other models. IIRC the relay is attached to the trim panel underneath the steering column on the Legacy. Try tapping on the relay while turning the key. Jim Link to comment Share on other sites More sharing options...
Project84 Posted March 2, 2006 Author Share Posted March 2, 2006 the Haynes repair manual says something about an Inhibitor relay that we think is making the noise when the key is in the on position, that ihibitor relay has something to do w/ both the neutral safety switch and the security system, we're checking there first today, then we'll check the relay under the dash as above suggested Link to comment Share on other sites More sharing options...
Project84 Posted March 3, 2006 Author Share Posted March 3, 2006 had something to do w/ the neutral safety switch, the gear selector/range selector on the transmission itself being rusty/loose jiggled the selector, noise went away, turned the key, vroooommmmmmmmm it was a good night, success at last! Link to comment Share on other sites More sharing options...
Aczwild Posted March 3, 2006 Share Posted March 3, 2006 I win!!!!!!!! JDM'd All to hell Thanks Jimmy @ Hkc-Speed.com! RIP Coxx & Thanks Link to comment Share on other sites More sharing options...
mothywheel Posted May 30, 2006 Share Posted May 30, 2006 This may be my problem. I've been thinking it was the starter interrupt but this morning when it wouldn't start I jiggled the gear shift and presto, she turned over easily. I'll get my mechanic to check it out. Did you have to replace it or just adjust it? The Neutral safety switch, I mean. Link to comment Share on other sites More sharing options...
dante2699yahoo.com Posted October 7, 2010 Share Posted October 7, 2010 Wherre is all this located? My car won't start. I hav a manual.does that make a difference? Link to comment Share on other sites More sharing options...
