team23jordan Posted February 12, 2006 Share Posted February 12, 2006 i just washed the car and found about 10 rock chips one huge one on the RBS grill and driver's side sidemirror bunch of'em in my RBS front lip and some on the hood and bumper i'm really thinking about getting a rock blocker now.. damn who makes the best touch up paint that matches up perfectly with our car? Perrin BIG maf intake Perrin Turbo Inlet HKS SSQV BOV Megan Racing header with UP (ceramic coated) HKS DP (WRX) DMH E-cutout Custom 3" catback UTEC Link to comment Share on other sites More sharing options...
team23jordan Posted February 12, 2006 Author Share Posted February 12, 2006 btw, my exhaust tips have stain from the exhaust fum.. i guess thats what i get from running catless oh my rear bumper had stains too...PITA too take it off Perrin BIG maf intake Perrin Turbo Inlet HKS SSQV BOV Megan Racing header with UP (ceramic coated) HKS DP (WRX) DMH E-cutout Custom 3" catback UTEC Link to comment Share on other sites More sharing options...
OCDetails Posted February 12, 2006 Share Posted February 12, 2006 http://www.paintscratch.com is a good place to get touch up paint. You just give them your paint code and they give you the paint. Unless you go to a local shop that mixes the paint based on an actual sample from your car, then paintscratch.com is just as good as anybody else. Even if the paint is a perfect match, you will still be able to tell that you touched up unless you are airbrushing the area. _________________________________________ “Cleanliness becomes more important as godliness becomes more unlikely.” O C D E T A I L S . C O M OCDETAILS BLOG Link to comment Share on other sites More sharing options...
OCDetails Posted February 12, 2006 Share Posted February 12, 2006 probably. However, unless you plan on sanding down a much larger area and airbrushing all three stages on, then a little touch up with the color coat is as good as you can hope to get. I wouldn't repaint a whole body panel that way, but it works for touch up. _________________________________________ “Cleanliness becomes more important as godliness becomes more unlikely.” O C D E T A I L S . C O M OCDETAILS BLOG Link to comment Share on other sites More sharing options...
PhilT Posted February 12, 2006 Share Posted February 12, 2006 I got a tube of the SWP touch up from the local dealer, but when you apply it, it's almost clear, like it needs a base coat underneath. I think I'll end up going to get a professional job done in the spring, once they've stopped gritting the roads. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
OCDetails Posted February 12, 2006 Share Posted February 12, 2006 From what I've experienced with touch up on my Legacy it seems that everything needs two coats to match properly. _________________________________________ “Cleanliness becomes more important as godliness becomes more unlikely.” O C D E T A I L S . C O M OCDETAILS BLOG Link to comment Share on other sites More sharing options...
G.T.Subie Posted February 12, 2006 Share Posted February 12, 2006 I used paintscratch on my OBP, matched well but has that egg shell look under the clear coat.Its on the bottom of the bumper so its nit that noticable.Plus it was my first time spray painting a car I will moat likely do it over in the spring. Denial is your best friend Link to comment Share on other sites More sharing options...
OCDetails Posted February 12, 2006 Share Posted February 12, 2006 You mean 'orange' peel and not 'egg shell', right? Either way, it is easy to avoid if you wetsand between layers. Give that a shot when you redo it and see if it helps. _________________________________________ “Cleanliness becomes more important as godliness becomes more unlikely.” O C D E T A I L S . C O M OCDETAILS BLOG Link to comment Share on other sites More sharing options...
jonnyg113 Posted February 14, 2006 Share Posted February 14, 2006 Try to use photoshop... stamp tool. Works for me.. Only if it was that easy Link to comment Share on other sites More sharing options...
