rabydanimal Posted February 8, 2006 Share Posted February 8, 2006 I checked this code on my parent's 2000 Legacy wagon with the access port I have for my '06. I cleared it and it didn't come back on a 10 mile drive where I tried tacing it up a couple times. Does low input mean it just can't read the sensor well and that it may need to be replaced or is it a real problem? Link to comment Share on other sites More sharing options...
GTsleeper Posted February 8, 2006 Share Posted February 8, 2006 most likly needs the knock sensor, its not uncommon. Link to comment Share on other sites More sharing options...
impostor Posted February 21, 2006 Share Posted February 21, 2006 Check to see if the sensor is cracked. Its fairly common with age. If its not cracked, take it off and check for corrosion between the sensor and the block. Jim Link to comment Share on other sites More sharing options...
mwiener2 Posted February 21, 2006 Share Posted February 21, 2006 wait a tic....you can use your AP to read codes off other subies?? My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
skibum0203 Posted June 2, 2019 Share Posted June 2, 2019 Dam 12 years later. Just threw this code on my 2005 OBXT. Hoping a part swap is all it needs. Link to comment Share on other sites More sharing options...
