rgsuby Posted February 6, 2006 Share Posted February 6, 2006 I just recently replaced all four tires on my LGT with BfGoodrich gforce Sports. http://www.tirerack.com/tires/tires.jsp?tireMake=BFGoodrich&tireModel=g-Force+Sport One of my RE92 started coming apart and I was in a bind therefore i had to choose from the selection Merchants tires had. In any case these tires looked fine. Anyways to my problem... My RE92 were never really quiet, but these new tires are loud. Most of the noise seems to be coming from the back of the car. I've even had backseat passengers comment on how loud the car is. I have messed around with the tire pressure. I've tried 35f 32r and now i'm running 39f 35r. Eitherway i'm still experinecing the same problem. The car drives and handles fine. Cruising on the interestate seems to be stable and smooth up to 90mph except for the noise. Do i need to have these tires balanced? or do i have a bad set? Thanks... Link to comment Share on other sites More sharing options...
Xenonk Posted February 6, 2006 Share Posted February 6, 2006 nope, sounds like a normal "buzz" to me that you are experiencing from the tire. You should hear a set of Falken Azenis, they are LOUD. the tires you bought are 340 treadwear, so the compound is a little bit harder than your RE92s most likely.. it's not a best way to rate a tire by it's loudness, but it could be an indication of why your tires are loud. Also, tire tread pattern also makes a difference (a good example is the Yokohama A032s vs A048s.. same compound material, just different in tread design). Keefe Link to comment Share on other sites More sharing options...
rgsuby Posted February 6, 2006 Author Share Posted February 6, 2006 Thanks, i'll learn to ignore it then... Link to comment Share on other sites More sharing options...
devobuzz Posted February 6, 2006 Share Posted February 6, 2006 Strange that the tire got a "8.0" rating on noise - which is in the excellent category. Move the back tires to the front and see what happens... Ralph Link to comment Share on other sites More sharing options...
Xenonk Posted February 6, 2006 Share Posted February 6, 2006 Thanks, i'll learn to ignore it then... volume 10 to 15 will fix it. Keefe Link to comment Share on other sites More sharing options...
VXCL Posted February 7, 2006 Share Posted February 7, 2006 are they direction tires? maybe the idiots installed one backwards. happened to my friend with khumo 712s on a civic. rear passenger side. it was loud. MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
Longitude Posted February 7, 2006 Share Posted February 7, 2006 Maybe off topic, but are stock STi tires (Bridgestone RE070) supposed to be noisy as well? I just picked me up, and I hate the howling at any speed. Link to comment Share on other sites More sharing options...
CreoSTi Posted February 7, 2006 Share Posted February 7, 2006 Maybe off topic, but are stock STi tires (Bridgestone RE070) supposed to be noisy as well? I just picked me up, and I hate the howling at any speed. Mine were pretty loud... But they were on an STi, which has minimal sound deadening to begin with. -Mike- Link to comment Share on other sites More sharing options...
rgsuby Posted February 7, 2006 Author Share Posted February 7, 2006 are they direction tires? maybe the idiots installed one backwards. happened to my friend with khumo 712s on a civic. rear passenger side. it was loud. Yup these are directionals. I will go check. It just seems most of the noise is coming from the back. Link to comment Share on other sites More sharing options...
rgsuby Posted February 7, 2006 Author Share Posted February 7, 2006 Yup these are directionals. I will go check. It just seems most of the noise is coming from the back. Just checked. Appears all 4 tires are facing the correct direction. I'm thinking about having a local shop rotate them and rebalance. Just to see if it helps... Link to comment Share on other sites More sharing options...
zildjiank Posted February 7, 2006 Share Posted February 7, 2006 I heard that those were loud tires from other people... Link to comment Share on other sites More sharing options...
jagcars26 Posted February 8, 2006 Share Posted February 8, 2006 My STi tires were loud also,,there was a great deal less noise when I went with the winter setup with A/S tires.Open tread designs are the most common source of tire noise,. Link to comment Share on other sites More sharing options...
boostsr20 Posted February 8, 2006 Share Posted February 8, 2006 Kumho MX's are loud as hell too. Link to comment Share on other sites More sharing options...
2Simpletons Posted February 8, 2006 Share Posted February 8, 2006 My RE070's are deafening at times. I rejoice when I hit fresh pavement... Link to comment Share on other sites More sharing options...
Xenonk Posted February 8, 2006 Share Posted February 8, 2006 Try driving on a set of Yokohama A032Rs.. they are louder than my engine and Greddy EVO2 exhaust combined on the road... Keefe Link to comment Share on other sites More sharing options...
EL PAALO Posted February 8, 2006 Share Posted February 8, 2006 gforce sports aren't loud ............ oh, wait ....... I didn't think yoko a520's or bfg kdw2's were loud either and everybody complained about both. too much time in the back of a herc. Link to comment Share on other sites More sharing options...
kster Posted February 9, 2006 Share Posted February 9, 2006 If you like your tires quiet, don't get the BFGoodrich KDW2 either, these are as loud as Azenis. Link to comment Share on other sites More sharing options...
