upper mounts for coilovers
rtp
Does anyone know which, if any, make of coilover out for our car has the option of a rubber or polyurethane upper mount instead of a solid metal pillowball mount? This would certainly be a benefit to those of us who are primarily commuters, want a significantly better ride, but without the noise.
these jdm teins have both a pillowball and some sort of upper rubber mount to help with ride comfort. im looking to get them myslef. should be about $1100-1200 shipped and since they come with top hats you dont need to take the oem shocks apart i believe. anyways scroll down to the superwagon setup. they also use much lower spring rates then others. only slightly more arressive them most lowering springs avail.
http://www.legacygt.com/forums/showthread.php?t=15541
MAYHEM
#122/22 STS NNJR SCCA
AUTOX4U.COM
XENON RETRO GUIDE
tien basic's and super street do. (though they don't make ss for our cars)
tien flex are solid.
so ur are saying the us tein basic come with top mounts as well as rubber bushings? i never knew that. do you have them? i would def be all over that cept for the spring rates. may be a bit too much for me. not sure though.
MAYHEM
AUTOX4U.COM
XENON RETRO GUIDE
The Basic's reuse your stock top hats.
Also important to remember what type of bearing the manufacturer is using !
I can easily put a bearing that costs 6$ into our mounts and lower the price 140$ !!! But, the part is going to make shitty clunking sounds and not be able to tolerate as high loads as a higher quality bearing.
The reason I will be suppling the kits with the PU piece is that metal to metal may not clunk, but transmits a lot more vibration than a PU part. The PU part will allow a lot more deflection than the pilo bearing.... need to have both options, especially for a street car.
(PU = Polyurethane)
-mark
