MrLWJ Posted February 3, 2009 Share Posted February 3, 2009 Ok it warmed up enough to install the NEO3 LED's.They are a snug fit but the fit, you do need to fire them up after installing to make sure the polarity is correct but they work GREAT.They will not dim totally but will dim a great deal. They are very bright and work great, just for S&G I put blue ones in.You can get them at Superbrightleds.com Look under the automotive section. And they are cheaper than factory.Larry Link to comment Share on other sites More sharing options...
jonklein611 Posted February 3, 2009 Share Posted February 3, 2009 Thanks for the info! Might have to upgrade, as I just had one burn out again.... grrrr Link to comment Share on other sites More sharing options...
excel1959 Posted February 19, 2009 Share Posted February 19, 2009 Followed this procedure this past weekend on my daughters '96, replaced the heater control bulbs and hazard button bulb with Radio Shack lights and it all looks great! Now before pulling everything apart again, does anyone know if the A/C button should light up when activated? Thanks to all. Link to comment Share on other sites More sharing options...
snowboarder_lgt Posted February 20, 2009 Share Posted February 20, 2009 Mine does - on a 98 Link to comment Share on other sites More sharing options...
jonklein611 Posted February 22, 2009 Share Posted February 22, 2009 Yes the AC will light up, but not in the defrost positions. Link to comment Share on other sites More sharing options...
sschmid Posted February 22, 2009 Share Posted February 22, 2009 OK so did anyone figure out how to change the bulb behind the clock on the stock radio. Just got this 98 Legacy and all climate control bulbs are blown as well as the clock and the one behind the (non existant) Tachometer. I will follow the change directions for the climate control bulbs (actually got half way before I was not sure where they were). Now I need to find the directions for the other two bulbs PLEASE!! Link to comment Share on other sites More sharing options...
excel1959 Posted February 24, 2009 Share Posted February 24, 2009 Well I pulled the heater control out again (getting good at that) in an attempt to replace the bulb in the AC switch. Did not find a way to get at the switch. Unfortunately I ran short on time. Anyone have any insight as to how to remove the AC switch from the heater control unit? Link to comment Share on other sites More sharing options...
cman7 Posted February 25, 2009 Share Posted February 25, 2009 Well I pulled the heater control out again (getting good at that) in an attempt to replace the bulb in the AC switch. Did not find a way to get at the switch. Unfortunately I ran short on time. Anyone have any insight as to how to remove the AC switch from the heater control unit? I'm not sure how to do this but I'd also like to know for the recirculation button. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted March 14, 2009 Share Posted March 14, 2009 Ok it warmed up enough to install the NEO3 LED's. They are a snug fit but the fit, you do need to fire them up after installing to make sure the polarity is correct but they work GREAT. They will not dim totally but will dim a great deal. They are very bright and work great, just for S&G I put blue ones in. You can get them at Superbrightleds.com Look under the automotive section. And they are cheaper than factory. Larry How is the lighting spread? I wanted to get a white LED to go for that area. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted March 14, 2009 Share Posted March 14, 2009 Warning! I went to the dealer to get the bulbs for the HVAC control and they gave me part number 72351AC051 for the car also for the 1995 Legacy L wagon they only show it as using 2 bulbs which is not true it has a total of 3 that I can see of and the bulbs they gave me were too long to fit. old bulb on the left http://img13.imageshack.us/img13/7453/dscf0055g.jpg Link to comment Share on other sites More sharing options...
MrLWJ Posted March 15, 2009 Share Posted March 15, 2009 How is the lighting spread? I wanted to get a white LED to go for that area. LIght spread is not perfect but not too bad either, the LEDS are cut flat on the end. If they were to be rounded off I think they would be perfect, better light spread. Still I am very happy with mine the color is very intense. Larry Link to comment Share on other sites More sharing options...
1-3-2-4 Posted March 15, 2009 Share Posted March 15, 2009 Ok well I will post pictures when they arrive. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted March 20, 2009 Share Posted March 20, 2009 keeping my word I just installed the LED's today looks better.. if I could open the case installing a mirror for the LED in the back you might be able to light up the icons for the air settings better.. http://img18.imageshack.us/img18/1787/img0076o.jpg Link to comment Share on other sites More sharing options...
jonklein611 Posted March 23, 2009 Share Posted March 23, 2009 Wow that looks good with LEDS, def brighter! Link to comment Share on other sites More sharing options...
1-3-2-4 Posted March 23, 2009 Share Posted March 23, 2009 yep much brighter and the hot spots are not that bad at all looks better in person. Link to comment Share on other sites More sharing options...
987687 Posted March 29, 2009 Share Posted March 29, 2009 OK so did anyone figure out how to change the bulb behind the clock on the stock radio. Just got this 98 Legacy and all climate control bulbs are blown as well as the clock and the one behind the (non existant) Tachometer. I will follow the change directions for the climate control bulbs (actually got half way before I was not sure where they were). Now I need to find the directions for the other two bulbs PLEASE!! No, they are soldered onto the radio. Mine were burned out behind the clock, so I soldered in other bulbs. But unless you want to go soldering (and find bulbs that work) you can't change them. (this was on a 1996 legacy, but the stock radio looks exactly the same as the '99, so I'm 99% sure it is the same on the 98 too) Link to comment Share on other sites More sharing options...
excel1959 Posted March 30, 2009 Share Posted March 30, 2009 What bulbs did you use for the radio? I used the same 12 volts that I used in the heater control to replace two in the radio and they are much dimmer than the two that were still working in the radio Link to comment Share on other sites More sharing options...
987687 Posted March 31, 2009 Share Posted March 31, 2009 I believe the radio is 8.something volts. I have a crap load of random stuff lying around, so I had some of the right voltage in a box... Link to comment Share on other sites More sharing options...
b707guy Posted May 13, 2009 Share Posted May 13, 2009 (edited) Another ecstatically happy customer of this thread! Our black hole of a center panel is now lit up like the streets of Las Vegas (compared to how it used to look, anyway... ). Thanks! Edited May 13, 2009 by b707guy Link to comment Share on other sites More sharing options...
amp27 Posted November 30, 2009 Share Posted November 30, 2009 hmm on superbrightleds.com you can get the part numbers for your car and get led's for your whole car. i personally love the color of led's in headlights. the cool blue tint. and if you wanna risk it you can tint your bulbs anycolor but your local pd may find it easier to to detect who's car it is at night. Link to comment Share on other sites More sharing options...
cman7 Posted November 30, 2009 Share Posted November 30, 2009 LED's or Light Emitting Diodes, come in many different colors. They're not all blue. Link to comment Share on other sites More sharing options...
amp27 Posted November 30, 2009 Share Posted November 30, 2009 yea but if you buy blue for your high beam it may be soo blue the cop will stop you. just like the 35w bridge. they install white led's but white led's can sometime have a blue tint. and when you light a bridge with them the tint becomes...well...more tint looking. ...they are talking about changing them but i think they are cool Link to comment Share on other sites More sharing options...
one bad bg Posted December 1, 2009 Share Posted December 1, 2009 http://legacygt.com/forums/picture.php?albumid=310&pictureid=2452 mine Link to comment Share on other sites More sharing options...
one bad bg Posted December 1, 2009 Share Posted December 1, 2009 hmm on superbrightleds.com you can get the part numbers for your car and get led's for your whole car. i personally love the color of led's in headlights. the cool blue tint. and if you wanna risk it you can tint your bulbs anycolor but your local pd may find it easier to to detect who's car it is at night. tint...did someone say tint you bulbs. nice someone else acually mentioned it. i went a step farther and tinted the lens, i dont have an updated pic but my fog are done too now http://legacygt.com/forums/picture.php?albumid=310&pictureid=1770 http://legacygt.com/forums/picture.php?albumid=310&pictureid=2453 Link to comment Share on other sites More sharing options...
cman7 Posted December 2, 2009 Share Posted December 2, 2009 tint...did someone say tint you bulbs. nice someone else acually mentioned it. i went a step farther and tinted the lens, i dont have an updated pic but my fog are done too now I'd rather keep my functionality of my non tinted bulbs and/or lights. Light output is reduced when you tint these components. As far as interior goes, these cars aren't exactly new. The bright and uneven lighting of the led's doesn't exactly match the rest of the interior IMO. Then again, it's your car, do what you will. I don't have to look at it everyday. Link to comment Share on other sites More sharing options...
