AMP Help
Jacket4256
Hey guys I am new to the car audio stuff , and I really dont know a whole lot about n-e of it at all. I am looking to put 3 10" MTX Audio 600 in my LGT and I am looking for a amp for it I have found this one http://www.pricegrabber.com/search_getprod.php/masterid=1172153 here. I just dont really understand the channel thing. My subs have one plug in for power is that like one channel??? Can anyone explain this to me or put me in the right direction. Thanks
Yes, that's like one channel. Each speaker input = 1 channel. That amp has 2 speaker outputs = 2 channel (stereo). First thing to know is what the impedance of your MTX box is - look for ? ohms. Probably 4, maybe 2. Then I'd find a D-class amp that operates in mono, that is has only one channel of output, since that's all you need, and is capable of driving x# of ohms. A D-class will give you more bang for your buck here. Look for mono amps, sub amps or class D amps.
http://www.cardomain.com/item/ROCCP2POS?ref=frog
sells everywhere for 99.99. fyi, manufacturer's "cost" is about $45 for the kit. i doubt you'd find anyone for selling it around that price though.
bumping 3 MTX subs?
http://www.pricegrabber.com/search_techspecs_full.php/masterid=3787394
use that amp! =D very very nice.... way too much $$$ however.
-- yay for the sig! --
my garage!
Oh, you're gonna hate this - that's really a 300w amp, the 1100w is peak. 4g is more than sufficient, you could even do 6g fine. You won't need a cap if that's the only amp.
Output PowerPeak Power Output (Watts x Channels): 1100 x 1Bridged Power (Watts x Channels): (what's this?)1100 x 1RMS Power Output (Watts x Channels): (what's this?)300 x 1
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=100-194
4g wire for $1.36/ft. Get 20 ft, plus 5' ground, some ring terminals & a fuse and 20 ft of 18g remote wire, you're under $40 easy.
The Java script didnt work man ??
Ok I am lost on the amp thing... How do I tell how much power I am pushing with the amp. I am looking for a good amp with like 1000 watts but I dont want to spend a fortune on it. Anyone have any ideas
what's 'a fortune' to you? A good, cheap amp, is an MBQuart RAA1000. 250W x @ 4ohms, 500x1 @2ohms and 1000wx1@1ohm. Going rate is about $200 on eBay
Are you sure you want 1000w of bass power? Is the rest of the system amped? Just trying to add some thump to your ride?
Check the Alphasonik amps, mono, class D on Ebay.
Alphasonik PMA800DA or Alphasonik PMA1000DA
HIFONICS TX1005D
Just don't get Audiobahn anything.
