crafty Posted January 19, 2006 Share Posted January 19, 2006 Ok, YES I did a search and found several IPOD connection theories and solutions. (keep your flame throwers in the case) Could someone give me the cliff notes on the newest, cleanest, easiest install...oh and it needs to work 05 leggt Thank You for the help Link to comment Share on other sites More sharing options...
SWP-LegacyGT Posted January 19, 2006 Share Posted January 19, 2006 Sadly... I'll say it.... Search harder. Link to comment Share on other sites More sharing options...
rosta Posted January 19, 2006 Share Posted January 19, 2006 which ipod? i've ordered a nano and may try this http://www.griffintechnology.com/products/tuneflex/index.php , unless I get impatient (likely) and try to fab something on my own. Link to comment Share on other sites More sharing options...
crafty Posted January 19, 2006 Author Share Posted January 19, 2006 If someone would share a link I would appreciate it. (It would probably take less time then telling me to search harder) I am not an electrical guy, and I would probably select the harder solution. Link to comment Share on other sites More sharing options...
SnoDork Posted January 19, 2006 Share Posted January 19, 2006 JazzyMT http://legacygt.com/forums/showthread.php?t=18504&highlight=jazzymt ~Sucka-Duck~ Link to comment Share on other sites More sharing options...
crafty Posted January 19, 2006 Author Share Posted January 19, 2006 rosta- thanks I will zoom in (I typed my last post and sent it the same time as you) Anyone have a completed install with the newest cleanest idea. I have a std IPOD with 6000 songs!! Link to comment Share on other sites More sharing options...
rosta Posted January 19, 2006 Share Posted January 19, 2006 JazzyMT http://legacygt.com/forums/showthread.php?t=18504&highlight=jazzymt crafty, check page 36, post 534. i would still read through the rest of the thread, there is lots of good info to absorb. Link to comment Share on other sites More sharing options...
boostsr20 Posted January 20, 2006 Share Posted January 20, 2006 Jazzy MT comes with excellent directions. They make it easy. It may seem intimidating at first but it really is simple. And it works flawlessly. Link to comment Share on other sites More sharing options...
Jon in CT Posted January 20, 2006 Share Posted January 20, 2006 Interesting survey results: http://www.nielsen-netratings.com/pr/pr_060119.pdf Link to comment Share on other sites More sharing options...
agctr Posted January 20, 2006 Share Posted January 20, 2006 For the extreme easy, use the FM Mod...... All the other systems do work and do work well although it requires removal and tinkering yrself. I know JazzyMT has a good solution and has worked a few updates since the original install. Sadly for the guys running McIntosh Units, there is still no progress on iPod Direct install. Ada///M. PS Thanks to the members that offered more advice including links, greatly appreciated. Link to comment Share on other sites More sharing options...
