going synthetic..
why avoid 30 weights? I run M1 Extended performance 5w30 and I am stage II protuned and it is great
using 10w30 no problems.....changed every 5k
Wait Don't you two lose like a quart every change?
Mobil 1 30 weights are thinner than most and turbos tend to beat them into 20 weights.
That may not be the case with you but many Subie owners, on NASIOC and BITOG, have commented that they go thru quarts with M1.
That's why you should do an oil analysis even if you're not consuming significant amounts of oil to see whether it's holding up or not, because if you wait till it starts consuming, the damage may have already been done.
I keed I keeed
IMO, you're wasting $ changing synth oil every 3k. Regular dino would probably be fine at 3k intervals. If you spend time researching the bobistheoilguy forums, you'll find that dino oils do quite well in most situations, and have proven to be more durable than I thought. I'm using a Havoline synth/dino blend for 5k intervals, will do a UOA to see how it's holding up. My guess is that it's holding up fine.
hm, i'm using Mobil 1 synth 0-40.. is that bad? i only use it cuz i get it for free at work.. i checked my oil last week, it was pretty low.. now i'm thinking if i should go back or not... all opinions are greatly appreciated
If it's from the rings:
- Check all spark plugs, the problematic cylinder would have a fouled plug
- Compression/Leakdown test
- Remove exhaust manifold and check the exhaust ports and uppipe(CAT too) for burned oil residue
If it's from the turbo:
- Check the intercooler for oil, could be leaking from the turbo cartridge seal
- Check the downpipe for burned oil residue, could be leaking from the turbo cartridge seal
If it's from the PCV valve:
I keed I keeed
IIRC NONE, I experienced the busted turbo cartridge and shattered ringlands/rings and it wasn't rootcaused till after an oil consumption test was done by the dealer. The only indication was the excessive oil consumption, which according to Subaru is around 1quart / 1000 miles.
I thought any consumption less than that was due to my driving so I waited till it was so bad to take to the dealer. In hindsight, I would've brought up the issue much earlier and pressed the dealer todo a compression/leakdown test and inspect the intercooler. This would've rootcaused the issue 15-20K miles earlier.
I keed I keeed
changed to amsoil 5-30. thisis supposed to be better than mobile 1 (may not be as thin) car runs smooth and silky, and feels like it has a taaaaaaad more power (stock motor) especially at high revs. it s only been 1200 miles since change( at 6000 mi) so cant tell if using oil.
Just changed to Amsoil 5/30 at 6000 kms.
HUGE difference in -25C weather....Huge. Starts are significantly easier.
Much smoother, feels that way anyway.
Reference the oil consumption issue....my 05 LGT wagon used approx 0.7 litre over the 6000 km interval. I've never had a car use this much oil before, but according to a mech at the dealership, he said this was well within acceptable limits for the turbo engine.
C
How much oil did you use? If you're getting M1 0-40 for free, I'd use that. It's a good synth oil, and meets the ACEA A3 spec (European spec), it's plenty good enough for our Subies. I won't use it simply because it goes for 6 bucks a quart around here, IMO it's just not worth the $, when I can spend a lot less than half that and still get oil that meets spec and will keep my engine healthy for many 100's of thousands of miles.
it was good when i closed the hood lol..
