Legacy05 Posted January 13, 2006 Share Posted January 13, 2006 Just a quick question to those that did the mod so you can have your fogs on with your parking lights. What guage wire did you use??? Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted January 13, 2006 Share Posted January 13, 2006 I think mine was 12 gauge. Link to comment Share on other sites More sharing options...
Legacy05 Posted January 13, 2006 Author Share Posted January 13, 2006 I think mine was 12 gauge. Thanks Jedi .. anyone want to confirm this!? Link to comment Share on other sites More sharing options...
mccorry Posted January 13, 2006 Share Posted January 13, 2006 I don't remember, specifically, but it isn't carrying alot of current. Just supplying a 12V signal to the coil. 10 or 12 gauge should be just fine. Link to comment Share on other sites More sharing options...
Deer Killer Posted January 13, 2006 Share Posted January 13, 2006 It's just relay power, 18 gauge should be ok. 12 gauge = huuuuge. Link to comment Share on other sites More sharing options...
Bicster Posted January 13, 2006 Share Posted January 13, 2006 It's just relay power, 18 gauge should be ok. 12 gauge = huuuuge. +eleventy Link to comment Share on other sites More sharing options...
mccorry Posted January 13, 2006 Share Posted January 13, 2006 Ah... I meant small. I don't know my wire sizes that well..... Link to comment Share on other sites More sharing options...
Bicster Posted January 13, 2006 Share Posted January 13, 2006 I ran 10-gauge wire to power my 240-volt, 30-amp air compressor Link to comment Share on other sites More sharing options...
executor485 Posted January 13, 2006 Share Posted January 13, 2006 12 guage is about what you need to run speakers with high wattage (not to the amp though). 18 guage should be plenty. If I pass you on the right, I'm flipping you off. Link to comment Share on other sites More sharing options...
Legacy05 Posted January 17, 2006 Author Share Posted January 17, 2006 Last question, should it be a solid wire or stranded wire? Will any 18 gauge wire work? Like 18 gauge speaker wire? Link to comment Share on other sites More sharing options...
Bicster Posted January 17, 2006 Share Posted January 17, 2006 I would not use speaker wire. Electrically it is fine, but get something that has colors that make sense, like red+black or yellow+black. (Disclaimer: I haven't seen this mod, so I don't know what connections are actually involved. Maybe other colors make more sense.) Stranded wire is much easier to work with. It's more flexible and easier to solder. Link to comment Share on other sites More sharing options...
Legacy05 Posted January 17, 2006 Author Share Posted January 17, 2006 Thanks .. just spoke to someone and they mentioned that I should match the wire if possible size wise, so it almost looks like 14 gauge wire. Link to comment Share on other sites More sharing options...
GTsleeper Posted January 17, 2006 Share Posted January 17, 2006 ^^ thats really ur best bet-- using the same wire as what ur connecting to Link to comment Share on other sites More sharing options...
mwiener2 Posted January 17, 2006 Share Posted January 17, 2006 don't use solid copper in cars. they don't flex much and over time, vibrations can casue them to break My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
John M Posted January 17, 2006 Share Posted January 17, 2006 The wiring inside the car is not 14 gauge. It's 16 at the biggest; probably closer to 18 to save weight and money. The fog mod circuit modificaiton carries about half an amp -- just enough to trigger the relay. That's barely any current at all so there's no reason to go with a giant wire. Don't over-think these things! See mod, like mod, do mod! Link to comment Share on other sites More sharing options...
Claw Posted January 17, 2006 Share Posted January 17, 2006 Don't mean to threadjack, but is it possible to have your fogs do double duty as DRL's and convert the headlights to them funky HID's? Link to comment Share on other sites More sharing options...
Bicster Posted January 17, 2006 Share Posted January 17, 2006 I think in some places it's illegal to run fogs when there's no fog...? Not sure. I saw some posts on the forum where people got ticketed for driving with their fogs on. Add HID's and run the risk of two tickets. Link to comment Share on other sites More sharing options...
TRS Posted January 17, 2006 Share Posted January 17, 2006 You can mod the fogs to turn on independantly of the parking lights and headlights (and even stay on with the highs if you want). So yes you will be able to have just the fogs on as your DRLs without any other lights on. Another option is to use this module to convert your front turn signals into DRLs. Link to comment Share on other sites More sharing options...
Claw Posted January 17, 2006 Share Posted January 17, 2006 I think in some places it's illegal to run fogs when there's no fog...? Not sure. I saw some posts on the forum where people got ticketed for driving with their fogs on. Add HID's and run the risk of two tickets. Ah, ok.. just wondering, as Audi's around here use their fogs as DRL's, same with Murano's... Link to comment Share on other sites More sharing options...
schwinn Posted January 19, 2006 Share Posted January 19, 2006 Yeah, but if you use a thicker wire, the lights will be brighter, the bulbs will last longer, and the car will be teh fast3st yo! </sarcasm> Link to comment Share on other sites More sharing options...
