just ordered this...
volcomst0ne24
I installed jazzy's adapter on saturday. I was pretty easy just take your time. It works great, don't forget to pick up your ground loop filter from radio shack($16) to make sure you dont get any engine noise.
Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com
Buy the Belkin. The mini plug goes in right by the power adaptor, so you don't have two cables running tp your iPod:
+1
werd. i've got this one installed in another ride it works well. less cables and you can adjust the output level if you need to.
i ordered the powered ipod plug/rca adapter. is an isolator still needed with this?
I haven't installed this yet, but I have the same adapter from autosound2000. I plan on grounding it to same point as the radio, that *should * negate the need for an isolator.
I'll let you guys know.
-Paul
OK, then, yep, it's noisy. Lots of electrical noise. I took power from the cigar lighter under the radio, and grounded it to the radio itself. With the car off, there is just a slight high-pitched whine when the radio is turned way up. With the car on, there is all kinds of whines and stuff. SHould I grab power from the radio harness? Or just stick a GLI on there and hope for the best?
-Paul
