mechdiff Posted January 9, 2006 Share Posted January 9, 2006 One of the things I hated with the starter on my old car was if I got in to my car mindlessly I would go through my regular routine and crank the engine when I already started the car with the remote. Anyone done this on their legacy? Is there a failsafe that allows the starter to not crank if the engine is running? I've never done it on my Legacy yet since I don't have a remote starter but I am thinking of getting one. I remember cringing everytime I did that in my old car. Link to comment Share on other sites More sharing options...
Chappy Posted January 9, 2006 Share Posted January 9, 2006 No failsafe..I did it once and cringed..I know I'll never do that again. Link to comment Share on other sites More sharing options...
Sub_Free Posted January 9, 2006 Share Posted January 9, 2006 I had a clifford alarm on my old Jeep and it had a failsafe so you wouldn't crank the starter if the car was already running. Link to comment Share on other sites More sharing options...
agctr Posted January 9, 2006 Share Posted January 9, 2006 What about cranking while in 1st? Any failsafe for that ? Ada///M. Link to comment Share on other sites More sharing options...
Windex Posted January 9, 2006 Share Posted January 9, 2006 Installed a few remote starters... Any remote starter worth its salt can be made to have a "failsafe" All you need is a 25a relay with the starter wire connected across the normally closed contacts. The remote starter should have an "I'm started" accessory power output, which then can be used to "deactivate" the relay when the engine is running. Voila, try as you might, you won't be able to inadvertantly mash the starter into the already turning flywheel. I cringe at the thought of how much $ a dual mass Subie flywheel costs... cheers Link to comment Share on other sites More sharing options...
