STiSubie109 Posted January 8, 2006 Share Posted January 8, 2006 Anyone else have this problem? The fuel door does not close all the way and is not flush with the body. I tried to adjust the plastic line attached to the gas cap thinking it was it with no luck, not quite sure what else i can do? Suggestions please!! Thanks in advance Link to comment Share on other sites More sharing options...
dougc Posted January 8, 2006 Share Posted January 8, 2006 I didn't have a problem w/ it closing. My problem is that it would not open when I pulled the latch. This happened on two different occasions. I would have to slide my car key in the gap of the fuel door, applying some pressure, then I would pull the latch, the car keys would fall to the ground and the door would pull open. This was a royal pain in the ass. The dealer had to replace the spring both times. Take it to the dealer, they will fix it under warranty. Link to comment Share on other sites More sharing options...
agctr Posted January 8, 2006 Share Posted January 8, 2006 Have a talk to yr SA @ the dealership and ask them to assist under warranty. Let us know how you go. Ada///M. Link to comment Share on other sites More sharing options...
Opie Posted January 8, 2006 Share Posted January 8, 2006 I didn't have a problem w/ it closing. My problem is that it would not open when I pulled the latch. This happened on two different occasions. I would have to slide my car key in the gap of the fuel door, applying some pressure, then I would pull the latch, the car keys would fall to the ground and the door would pull open. This was a royal pain in the ass. The dealer had to replace the spring both times. Take it to the dealer, they will fix it under warranty. If they are replacing your fuel door spring...they are not fixing the problem... Look here: http://www.thel7.com/TSB/09-40-04.pdf Link to comment Share on other sites More sharing options...
dougc Posted January 8, 2006 Share Posted January 8, 2006 hmm..ok..maybe that is what they meant. I don't know...I don't care...all that matters is that it works perfect now. Link to comment Share on other sites More sharing options...
mudfoot Posted January 8, 2006 Share Posted January 8, 2006 Thank you Opie Got Torque ? Link to comment Share on other sites More sharing options...
Rollin Wes Posted January 11, 2006 Share Posted January 11, 2006 Had the same problem where my fuel door would not open. The dealer installed the clip and it works fine now. About three months now with no problems. Link to comment Share on other sites More sharing options...
Chappy Posted January 16, 2006 Share Posted January 16, 2006 My WRX would get stuck closed all the time. I used to pry it open with a credit card. Link to comment Share on other sites More sharing options...
