Posted
So, my left headlight went out.  Bulb is good, fuses good.  When reinstalling the bulb, noticed the wire right outside of the connector is bare.  Cannot get a new wire harness from subaru - discontinued.  Will drop by the local u-pull, but just wondering if anyone knows or has a picture of where the wire is routed so I can grab the whole thing without having to cut/splice?
Thanks!
Posted
From what I recall the passenger side headlight harness connects and drops down to go under your rad support/AC Condenser and then up towards your drivers side headlight, but it is part of the engine bay harness/engine bay fuse box there is not a disconnection point iirc.
  • Like 1
#LGTSTi is still cheaper and nicer then an equal year wrxsti
Follow my 2007 Spec B. Build here
Posted
Yeah, a cursory look in my engine bay didn't reveal an obvious connection point.  That's fine, my plan is to hit the u-pull and just cut off the section I need - the actual h/l connector and attached wiring.  Then I can just splice together.  Hopefully won't have to smack my headlight housing to get it to turn on.
  • Like 1
