seanyb505 Posted November 22 Posted November 22 (edited) I acquired a damd steering wheel a few years back but the seller didn't include the control "blanks". As a result I haven't installed the thing yet. I'll also be installing an 08+ head unit as my CD player is pretty much dead. So this leaves me with a few ideas ranging from bondo up some garbage steering wheel spoke controls to wiring up pre-facelift controls to work with a facelift head unit. Ultimately the general shape and outline of the controls need to be 05-07. Thanks! Edited November 22 by seanyb505
Underdog Posted November 23 Posted November 23 I may still have the blanks from my 05-07 DAMD wheel, if you strike out on a set of controls. Also, I measured the resistance across each button at one point, and put that info somewhere here on the forum (my build thread, maybe?)… Not sure if DIY controls is in your project scope, but could be a good starting point. I know the physical layout changed for 08-09 but maybe they kept the same resistance values? Edit: found em… Mode = 333 ohms Up Arrow = 600 ohms Down Arrow = 1141 ohms + Volume = 88 ohms - Volume = 190 ohms Mute = 22 ohms The Crimson Dynamo
BoozeRS05 Posted November 23 Posted November 23 I’m nearly certain I have a set from an 05 Outback and 08 specB that I’ll never use. Think I actually know where they are too. EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving
seanyb505 Posted November 23 Author Posted November 23 1 hour ago, Underdog said: I may still have the blanks from my 05-07 DAMD wheel, if you strike out on a set of controls. Also, I measured the resistance across each button at one point, and put that info somewhere here on the forum (my build thread, maybe?)… Not sure if DIY controls is in your project scope, but could be a good starting point. I know the physical layout changed for 08-09 but maybe they kept the same resistance values? Edit: found em… Mode = 333 ohms Up Arrow = 600 ohms Down Arrow = 1141 ohms + Volume = 88 ohms - Volume = 190 ohms Mute = 22 ohms Actually if you have the blanks I'd love to go that route for project simplicity. If you have them and can find them let me know what you want for them. I think I've seen a write up on getting 05 controls working with the 08 radio. It's definitely not the driving force in this scope though. 56 minutes ago, BoozeRS05 said: I’m nearly certain I have a set from an 05 Outback and 08 specB that I’ll never use. Think I actually know where they are too. Thanks - if Underdog can't find the blanks I'll be in touch. I think the 08s are a different shape, so they might not fit the damd wheel and 05 airbag.
Underdog Posted November 29 Posted November 29 Looks great! Glad they worked for you. The Crimson Dynamo
