EJ253 with Variable Vale Lift valve lash adjustment question.
In the picture I cired the pin the engages or disengages the VVL. When setting the valve lash on the left intake rocker (as pictured) it obvious to just set it.
The right rocker rides on a small cam with little lift when the pin is disengaged. When the pin is engaged it rides on the normal cam.
When adjusting the valve lash should the pin be manually engaged to rest on the normal cam?
