solidxsnake Posted August 29 Share Posted August 29 Year, Make and Model: 2007 Legacy GT spec.B Color: Diamond Grey Metallic Miles: 175k Transmission: 6MT Title: Clean Lien: N/A Location: Nashua, NH VIN: 4S3BL696773201624 Seller's email address: shamitsom@gmail.com Asking Price: 12,000 For sale is my 2007 spec.B. Car was purchased by me off of LegacyGT forums in 2015, I think I'm 6th owner. Car was originally from CA/NV, eventually made its way to CT before I bought it. It was used for daily driver duties and occasional autocross. For the two winters it was driven in my ownership, the underside was coated in Fluid Film. There is no rust to speak of since it was not a New England car for long before I bought it, and it hasn't seen a winter since 2016. Always garaged. The original motor lost compression in cyl2 in 2017. A built motor was eventually swapped in around 167k miles, and since then, the car has only seen autocross and track use since (probably about 15 autocross events and 5 track days). Car is in excellent running condition, and would be a great starting point for a proper dedicated track car. I'm interested in changing platforms, so looking to sell the car to someone who'll enjoy it. New motor (<10k miles) has fully forged internals and was spec'd to handle 450-500whp reliably. All that's left to reach that would be a bigger turbo, injectors, and a tune, all other supporting mods have been done. Engine replaced at 166.5k miles, spec'd to handle 450-500whp: OEM EJ255/257 shortblock machined and assembled by Larry's Auto Machine in Groton, CT OEM STI 11mm oil pump OEM STI nitrided crank OEM oil cooler Rallispec forged rods Manley forged pistons King main/rod bearings ARP head studs Rebuilt D25 heads (valve lapping, new guides, new OEM buckets for clearances) Aisin timing belt kit Koyo VH091662 radiator Killer B oil pickup Killer B baffle Killer B Holy Header w/ V-band uppipe and Swaintech coating Cobb 3" catted downpipe SPT v2 catback exhaust and Vibrant 1142 resonator SPT turbo heatshield JMP VF46 Custom (installed on original motor around 117k miles) Grimmspeed 3-port EBCS + Hallman Pro RX manual boost controller (hybrid electronic/manual boost control) AEM dry-flow air filter Perrin turbo inlet hose IAG Air-Oil Separator (v2 Competition) Grimmspeed top-mount intercooler JDM manifold runners (TGV deletes) Fluidampr crank pulley Spartan 2 + Bosch LSU 4.9 wideband O2 sensor (mounted in downpipe bung, wired into rear O2 sensor) Cobb fuel pressure gauge (wired into LH TGV) Secondary Air Pump delete + KSTech block-off plates AEM320 fuel pump Fumoto F105N drain valve Open-source tuned, targets 18-19psi peak boost on 93 pump gas. Was dyno tuned on the original motor by Mike Kinsman (Tuning Alliance) at Enhanced Street Performance in Sterling, MA, and originally put out 270whp/315ft-lb wtq on the Mustang dyno @ ESP. Tune has been further tweaked by me after replacing the motor. Chassis/Suspension/Brakes: Southbend Stage 2 Daily clutch kit @ 166.5k with new motor New OEM clutch master cylinder Group N motor, transmission, and pitch-stop mounts @ 150k Cobb 6MT short-throw shifter Cobb shifter bushings 2019 STI steering rack (34110VA121) 15+ STI steering U-joint (34170VA030) Whiteline KSR207 steering rack bushings Rallitek Skid Plate Redshift coilovers w/ Swift springs and camber plates (BC racing revalves) Hotchkis front and rear sway bars (25mm and 22mm, I believe) Whiteline W0406-24 and W0406-22 rear/front sway bar bushings Whiteline KLC144 rear adjustable endlinks Whiteline KLC139 front adjustable endlinks AVO rear sway bar reinforcement brackets Whiteline KTA124 Rear Control Arms Whiteline KCA313 Bump-steer/roll-center kit Whiteline KCA334 caster/anti-lift bushings Whiteline 0506 front inner LCA bushings Whiteline 63394 rear outer LCA bushings Whiteline 63396 rear inner UCA bushings Whiteline 63397 near outer UCA bushings Whiteline 63398 trailing arm front bushings Whiteline KDT927 rear diff bushing inserts Raxles re-built front axles @ 172k Timken wheel bearings @ 118k Hawk HP+ front and HP5.0 rear pads Grimmspeed brake master cylinder brace [NOT INSTALLED] front 4-pot '04 STI gold Brembos, rear 2-pot FHI rear WRX calipers (needs rebuild and adapter bracket and '04 STI front rotors), PowerStop stainless brake line kits for front/rear 18x10.5 ET35 Enkei RPF-1 wrapped in 265/35R18 Kumho V730s (very rare wheels!) 18x7 ET50 OEM '06-'07 spec.B wheels wrapped in 215/40R17 Michelin X-Ice 3 ('16 date codes, tires aren't of use anymore) Cut and sealed fenders + flares (liners removed) Others: DAMD D-shaped steering wheel with carbon-fiber top (OEM airbag and steering wheel controls retained) STI leather/aluminum weighted shift knob (C1010VC100) OEM JDM rain visors 3M Crystalline CR40 tints on all glass besides front windshield [NOT INSTALLED] RallyArmor mudflaps (grey text) Spare coils, plugs, various small parts leftover 1 Link to comment Share on other sites More sharing options...
I Donated bucko3the7man Posted August 29 I Donated Share Posted August 29 Wow that’s a really good looking front grill. Whoever made that put a lot of effort into it in 2012 GLWS, solid seller here 1 Link to comment Share on other sites More sharing options...
boxkita Posted August 30 Share Posted August 30 8 hours ago, bucko3the7man said: Wow that’s a really good looking front grill. Whoever made that put a lot of effort into it in 2012 GLWS, solid seller here was this yer car at one point? or just the grill fabrication? Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
solidxsnake Posted August 30 Author Share Posted August 30 Just the grille, he gave it to me along with the hotchkis bars before he sold his LGT 1 Link to comment Share on other sites More sharing options...
boxkita Posted August 30 Share Posted August 30 Geez, if everyone commented on each thing they had contributed to a car, itd be like vinwiki with history 1 4 Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
I Donated bucko3the7man Posted September 4 I Donated Share Posted September 4 On 8/30/2024 at 11:24 AM, boxkita said: Geez, if everyone commented on each thing they had contributed to a car, itd be like vinwiki with history Solidsnake is also a close friend, this is my way of ribbing him for including every other thing in the listing. Love you buddy! 1 1 Link to comment Share on other sites More sharing options...
