amerizon39 Posted July 13 Share Posted July 13 Not sure if this is the correct place to post this. First my left low beam headlight went out and then a couple days later the right one went out I checked the bulbs they're good I even bought new ones and that didn't work. I checked the fuses they're good I checked the relays and they're good now I'm not sure what my next step should be Link to comment Share on other sites More sharing options...
silverton Posted July 13 Share Posted July 13 it's kinda weird one would go out, then the other and then completely inop. they're triggered together as far as I can tell in the wiring diagram. your DRL module could be suspect, or even the headlight switch itself. Link to comment Share on other sites More sharing options...
amerizon39 Posted August 11 Author Share Posted August 11 Thank you for responding. I have anoth er car that has some issues so this is the first I've been able to get back to the head light issue. Is there a way to test or by pass the dlr module. Where is that located. Link to comment Share on other sites More sharing options...
