Ultra-Filter
I have a CM 25-282 spin-on oil filter. Around 15,000 miles with it on. I'm happy with the UOAs.
Aside from the excess of apostrophes in their marketing literature, that looks like an interesting filter.
I just ran across this one. It looks like it should filter similarly well, but it's disposable:
http://www.amsoil.com/products/ea_filters/EaO.aspx
Edit: The EAO12 fits the GT. $15.75. Anyone who knows about this stuff care to comment on this beast?
There are some serious claims in there, and I would love to see them proven.
On one hand they are saying that the oil pressure in the average filter will increase as you increase the performance, but then they say that most filters will run on bypass anyway, which is it ?
As the oil pump is directly driven, the volume of oil is directly proportional to the speed of the engine, and as it's impossible to compress a liquid, the pressure is relative to the bearing clearances. I would imagine there is a small relief valve in the pump somewhere to maintain a fairly constant pressure once above idle.
And as for gains of 5 - 6 hp , I have to call BS on this one :munch:
Did you confirm this by fitting the filter? The reason I'm asking is the last time I called Amsoil to place an order, the girl on the phone said they didn't have anything for our cars.
I put in two of the Subaru P/N's for our oil filters and they both came back with the same fitment. She probably told you that because if you look it up under Subaru, they don't show any fitments... Strange. The P/N X-ref clearly shows it's a Subaru part, though.
I see. I guess I'll try one out on my next oil change. If they are anything like the older Amsoil filters they should be really good. On other cars where I've used Amsoil filters the oil stays honey coloured for the entire oil change interval.
