Outback Shocks / ADJ?
Zestymac
Are there any adj shocks (struts) for thew 05' / 06' Outback? I'd like to dial in a bit more firmness for the day to day driving.
Maybe even a coilover to be able to fiddle a bit with the ride height.
I want to stay mostly stock with a height change up for when I'm at the beach for two weeks driving on the soft sand...
Thanks, Rick
Not much in the way of Outback-specific stuff out there. Seems the idea is to use Legacy (aftermarket, of course) adjustable coilovers cranked up as high as they can go. Which will still probably lower it a bit, and may be incompatible with the occasional rough-road or intentional off-road excursion.
I'm looking into a mild rear sway bar upgrade (17mm OEM GT, or 18mm Cusco), & stiff end links. And figure out how to get some camber.
Suggest asking over at outback.org.
06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest.
