Jolbaru_LGT Posted June 10, 2023 Share Posted June 10, 2023 So, I do have a rebuilt serviceable driveshaft. I just for reference.. Maybe it was from the driveshaft store? I’d have to look at my records. But anyways, it’s making a helicopter kinda noise right under the car and is that normal NVH or is the “serviceable” U-joint bad? Also, if that’s what it is, is it bad and potentially dangerous to drive it like that? Like, could it snap and all that? Just wondering if anyone else experienced this, and how easy is it to fix it myself and source the part for those U-joints? Thanks! Link to comment Share on other sites More sharing options...
KZJonny Posted June 10, 2023 Share Posted June 10, 2023 No. Maybe. Yes, A little. Probably not, but do you want to find out? Seriously, it’s not that hard of a job. Pulling the driveshaft is just 6 bolts. You should be able to see any play in it if it’s making that much noise. I would imagine whoever made the driveshaft will be able to tell you what part you need. Most likely it’s something like a Ford F150 joint or whatever. Something that will handle the power and is ultra common at parts shops. Link to comment Share on other sites More sharing options...
Jolbaru_LGT Posted June 11, 2023 Author Share Posted June 11, 2023 Looks like the exhaust is in the way and a heat shield? Yargh. Last time I did a driveshaft rebuild was on a 90 Volvo 245. I’m sure the LGT is quite different. I know I took it all off once before, and I can do it again. but I’d be worried that I couldn’t get balanced right or whatever. At that point, would it be better to buy a “new” Driveshaft shop one? Or what’s even the point of serviceable one? Link to comment Share on other sites More sharing options...
Jolbaru_LGT Posted July 5, 2023 Author Share Posted July 5, 2023 Update: Still didn’t find anything wrong, although the sound isn’t as noticeable with the summer tires on. Could be the snows need a balance? Link to comment Share on other sites More sharing options...
pleiadesfella Posted July 5, 2023 Share Posted July 5, 2023 could it just be tread noise from your winters? my blizzaks are loud as hell and they make a very distinct and loud woodpecker kind of sound from under the car at freeway speeds. Link to comment Share on other sites More sharing options...
