Matthew VanSkyock Posted June 9, 2023 Share Posted June 9, 2023 I just have a question for the site, is a broken 2.5gt engine worth anything? Was told it was a broken rod bearing or crank bearing...??? Link to comment Share on other sites More sharing options...
SoobyDoobyDoo Posted June 13, 2023 Share Posted June 13, 2023 (edited) Nope. You’re better off getting a new short block. Don’t try to get or rebuild one with a spun bearing or broken rod. You’ll just create new problems for yourself in the future. Just scrap it for what it’s worth. Also, rod bearings and crank bearings are the same thing. Edited June 13, 2023 by SoobyDoobyDoo Link to comment Share on other sites More sharing options...
Matthew VanSkyock Posted June 13, 2023 Author Share Posted June 13, 2023 So it hopless to try and sell it the way it is? Link to comment Share on other sites More sharing options...
SoobyDoobyDoo Posted June 14, 2023 Share Posted June 14, 2023 You can always try but it’s not advisable to try to rebuild a block like that. If a bearing spun the crank will need to be machined and then use larger bearings, which I don’t think these engines like very much. Is it just the block or do you have heads as well? You might try selling just the heads, might have more luck with that. Link to comment Share on other sites More sharing options...
Matthew VanSkyock Posted June 14, 2023 Author Share Posted June 14, 2023 OK got it, and yes its the hole engine minus the intake is all. Its a tubro version 2.5 with extra left over parts from a engine swap, had to put a 2.0 turbo in instead which sucks car don't pull like it did with the 2.5. Link to comment Share on other sites More sharing options...
m sprank Posted June 14, 2023 Share Posted June 14, 2023 No one will want a blown engine. I get offered them for free all the time. You might find interest in specific parts from the engine. Possibly the heads. But you will need to remove them and at least visually inspect. Might find a buyer for the intake manifold, TB assembly, TGV's, Wiring harness, etc. Link to comment Share on other sites More sharing options...
Matthew VanSkyock Posted June 14, 2023 Author Share Posted June 14, 2023 All good info , thank you for your help. Link to comment Share on other sites More sharing options...
