yellowspirit Posted March 26 Share Posted March 26 Does anyone know if the connection on the back of the intake manifold is replaceable or is it part of the intake manifold? 2008 Subaru Legacy GT 5EAT. I seem unable to find it on the 3 most associated parts diagrams. Maybe I'm looking at the wrong parts diagram. https://parts.subaru.com/a/Subaru_2008_Legacy-25L-TURBO-5AT-4WD-GT-Limited-Sedan/_54102_6026548/INTAKE-MANIFOLD-INTAKEMANIFOLD-SYSTEM--THROTTLE-07MY-/B13-050-21.html https://parts.subaru.com/a/Subaru_2008_Legacy-25L-TURBO-5AT-4WD-GT-Limited-Sedan/_54102_6026546/INTAKE-MANIFOLD-INTAKEMANIFOLD-BODY--PCV-PIPE-07MY-/B13-050-22.html https://parts.subaru.com/a/Subaru_2008_Legacy-25L-TURBO-5AT-4WD-GT-Limited-Sedan/_54102_6026428/INTAKE-MANIFOLD-FUEL-PIPE--FUEL-INJECTOR-07MY-/B13-050-23.html Link to comment Share on other sites More sharing options...
Infosecdad Posted March 27 Share Posted March 27 Looks like it's part of the manifold on the parts diagram. Looks like it's removable though, why are you looking to replace it? Link to comment Share on other sites More sharing options...
yellowspirit Posted March 27 Author Share Posted March 27 5 hours ago, Infosecdad said: Looks like it's part of the manifold on the parts diagram. Looks like it's removable though, why are you looking to replace it? I was going to replace it if it was something like the PCV because I'm diagnosing an issue that may be caused by the vacuum system for the brakes. However, I did remove it and it's literally just a simple connector. So I'm no longer going to replace it. 1 Link to comment Share on other sites More sharing options...
silverton Posted March 27 Share Posted March 27 I'm pretty confident that's the fitting for the brake booster hose 1 Link to comment Share on other sites More sharing options...
Max Capacity Posted April 8 Share Posted April 8 Yep, I just walked out and checked my 09. Brake booster hose. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
yellowspirit Posted April 9 Author Share Posted April 9 (edited) On 3/27/2023 at 7:31 PM, silverton said: I'm pretty confident that's the fitting for the brake booster hose 7 hours ago, Max Capacity said: Yep, I just walked out and checked my 09. Brake booster hose. Are you guys sure - the metal fitting? I guess it's possible I messed this up when I was reassembling the intake manifold. Perhaps I connected the vacuum hoses to the wrong fittings and that's why all my brake calipers were locking up. https://parts.subaru.com/a/Subaru_2008_Legacy-25L-TURBO-5AT-4WD-GT-Limited-Sedan/_54102_6026546/INTAKE-MANIFOLD-INTAKEMANIFOLD-BODY--PCV-PIPE-07MY-/B13-050-22.html What connects to the small (plastic) fitting of the 3? I suppose it's actually "1AD21" - the vacuum hose coming off the PCV since it's not labeled as either "A" or "B". Edited April 9 by yellowspirit Link to comment Share on other sites More sharing options...
Infosecdad Posted April 9 Share Posted April 9 1 hour ago, yellowspirit said: Are you guys sure - the metal fitting? I guess it's possible I messed this up when I was reassembling the intake manifold. Perhaps I connected the vacuum hoses to the wrong fittings and that's why all my brake calipers were locking up. https://parts.subaru.com/a/Subaru_2008_Legacy-25L-TURBO-5AT-4WD-GT-Limited-Sedan/_54102_6026546/INTAKE-MANIFOLD-INTAKEMANIFOLD-BODY--PCV-PIPE-07MY-/B13-050-22.html What connects to the small (plastic) fitting of the 3? I suppose it's actually "1AD21" - the vacuum hose coming off the PCV since it's not labeled as either "A" or "B" I don't think that's right. The other end of the hose that connects to A goes to "Fig 261", which is the figure for the brake booster: https://parts.subaru.com/a/Subaru_2008_Legacy-25L-TURBO-5AT-4WD-GT-Limited-Sedan/_54106_6022650/BRAKE-PIPING-FRONT-WITH-OUT-VDC/B13-265-01.html Link to comment Share on other sites More sharing options...
yellowspirit Posted April 9 Author Share Posted April 9 9 hours ago, Infosecdad said: I don't think that's right. The other end of the hose that connects to A goes to "Fig 261", which is the figure for the brake booster: https://parts.subaru.com/a/Subaru_2008_Legacy-25L-TURBO-5AT-4WD-GT-Limited-Sedan/_54106_6022650/BRAKE-PIPING-FRONT-WITH-OUT-VDC/B13-265-01.html That's why I think you guys are right and I probably connected the hoses incorrectly. The PCV hose can be physically forced onto that metal fitting but it looks ballooned out so that's why I think I'm wrong. And that may be causing the braking system to function incorrectly as it was. 1 Link to comment Share on other sites More sharing options...
Max Capacity Posted April 9 Share Posted April 9 I grabbed my hose and shuck it, and the other end clearly went to the brake booster. With the big Grimmspeed tmic it's easy to see. 1 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted April 9 Share Posted April 9 1 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
m sprank Posted April 14 Share Posted April 14 That is the brake booster to manifold connection. I have spoken. This is the Way. 1 Link to comment Share on other sites More sharing options...
RumblyXT Posted April 15 Share Posted April 15 (edited) ^^I think you are mistaken. Not sure if this diagram can help.. follow the yellow line Edited April 15 by RumblyXT Link to comment Share on other sites More sharing options...
RumblyXT Posted April 15 Share Posted April 15 (edited) ^^According to that diagram, the big aluminum fitting on that area seem to go to the PCV valve. The plastic fitting to the bottom right of the metal fitting goes to the brake booster.. again, according to this diagram. Edited April 15 by RumblyXT Link to comment Share on other sites More sharing options...
RumblyXT Posted April 15 Share Posted April 15 This video was very helpful for me too.. welcome to Subaru's many vacuum lines. Link to comment Share on other sites More sharing options...
RumblyXT Posted April 15 Share Posted April 15 At minute 10:20 of the video, you can see him taking the brake booster hose to the plastic fitting I mentioned, the yellow line on the diagram. At 15:53, you can see the PCV hose goes to the metal fitting. The colored diagram I attached is correct. The metal fitting vacuum hose goes to the PVC, not the brake booster. Link to comment Share on other sites More sharing options...
m sprank Posted April 16 Share Posted April 16 Its all the same in the end. A reference to manifold. No valves, dampers, etc. Just an orifice of a size to fit a hose. Link to comment Share on other sites More sharing options...
RumblyXT Posted April 16 Share Posted April 16 Hmm.. yeah I’m not sure I agree with that. if that had been the case, his brake booster would have probably worked ok. Link to comment Share on other sites More sharing options...
RumblyXT Posted April 16 Share Posted April 16 I might be wrong, but based on the ID size of that metal fitting, it seems the amount of vacuumed air needed to operate the brake booster diaphragm is much less than for the PCV valve assy/system. Link to comment Share on other sites More sharing options...
m sprank Posted April 17 Share Posted April 17 If you cant recognize that the hose you are trying to fit to a nipple is too small and the force required too great, maybe you should not be working on machinery. Just because there is a You Tube video or a diagram does not mean you are skilled enough to accomplish the task properly. Link to comment Share on other sites More sharing options...
RumblyXT Posted April 17 Share Posted April 17 (edited) On 4/16/2023 at 1:05 AM, m sprank said: Its all the same in the end. A reference to manifold. No valves, dampers, etc. Just an orifice of a size to fit a hose. This statement leads me to think you were mistaken. How could it be “all the same in the end”? Is this your approach to machinery too? Each peep should have its corresponding destination.. I listed two sources: the diagram and that guy’s video. So you’re saying they’re both wrong? It can be really confusing with all these vacuum hoses entanglement.. why is it so difficult for some to say I was wrong.. because I have absolutely no problem at all with it. We’re only human and in the end we’re here to help each other out not to bash or look down on others. Edited April 17 by RumblyXT Link to comment Share on other sites More sharing options...
yellowspirit Posted May 5 Author Share Posted May 5 (edited) On 4/17/2023 at 12:42 PM, RumblyXT said: This statement leads me to think you were mistaken. How could it be “all the same in the end”? Is this your approach to machinery too? Each peep should have its corresponding destination.. I listed two sources: the diagram and that guy’s video. So you’re saying they’re both wrong? It can be really confusing with all these vacuum hoses entanglement.. why is it so difficult for some to say I was wrong.. because I have absolutely no problem at all with it. We’re only human and in the end we’re here to help each other out not to bash or look down on others. I will say that the length and bend of the new PCV valve hose seems to go right into the metal fitting instead of the other plastic fitting. Is it possible this part of the intake manifold design changed between the 05-06 and 07-09 cars? On 4/17/2023 at 7:59 AM, m sprank said: If you cant recognize that the hose you are trying to fit to a nipple is too small and the force required too great, maybe you should not be working on machinery. Just because there is a You Tube video or a diagram does not mean you are skilled enough to accomplish the task properly. It didn't seem like it took much effort at all to fit that hose onto the metal fitting. It literally slid right on there. Edited May 5 by yellowspirit Link to comment Share on other sites More sharing options...
yellowspirit Posted May 5 Author Share Posted May 5 On 4/16/2023 at 2:26 PM, RumblyXT said: Hmm.. yeah I’m not sure I agree with that. if that had been the case, his brake booster would have probably worked ok. I will say that I'm not sure the brake booster is the problem either. I've been parts cannoning the shit out of this. It might even be the master cylinder (a new one from RockAuto may be the issue). I've ordered a genuine Subaru one as a replacement. Link to comment Share on other sites More sharing options...
m sprank Posted May 5 Share Posted May 5 (edited) We went over this back in like 2010, lol. There was a slight change to the manifold for 07-09. Edited May 5 by m sprank 1 2 Link to comment Share on other sites More sharing options...
yellowspirit Posted May 21 Author Share Posted May 21 So turns out the fix was a genuine Subaru brake master cylinder. The one I bought months ago from RockAuto was junk. You figure if manufacturers are having quality issues, how bad is it for the aftermarket? 1 1 Link to comment Share on other sites More sharing options...
silverton Posted May 21 Share Posted May 21 I put a rockauto steering rack in my third gen ~25k miles ago. It needs a new rack already, the inners both have way too much play. I'll always recommend dealer parts vs aftermarket. Even the 'peanut' marker bulbs are so much brighter than the 194's you'll get from oreillys. 2 Link to comment Share on other sites More sharing options...
