Infosecdad Posted April 18, 2023 Share Posted April 18, 2023 2 minutes ago, drewmandrew99 said: Source? I believe that the standard Rom Raider ECU defs included 2008/09 LGT definitions. https://www.romraider.com/forum/topic360.html USDM - A2TB001N (2008/09 USDM Legacy(Outback) GT(XT) MT) Link to comment Share on other sites More sharing options...
drewmandrew99 Posted April 18, 2023 Author Share Posted April 18, 2023 1 minute ago, Infosecdad said: I believe that the standard Rom Raider ECU defs included 2008/09 LGT definitions. https://www.romraider.com/forum/topic360.html USDM - A2TB001N (2008/09 USDM Legacy(Outback) GT(XT) MT) unfortunately Its an auto those are manual defs Link to comment Share on other sites More sharing options...
Infosecdad Posted April 18, 2023 Share Posted April 18, 2023 20 minutes ago, drewmandrew99 said: unfortunately Its an auto those are manual defs What about an '08 GT AT? https://www.romraider.com/Documentation/SupportedECUs Legacy/Outback GT/XT08 A2TB001C (AT)*08/09 A2TB001N (MT)* Link to comment Share on other sites More sharing options...
drewmandrew99 Posted April 18, 2023 Author Share Posted April 18, 2023 I'll link it to my tuner that actually looks helpful also found this post from forever ago could be a similar instance to this. 1 Link to comment Share on other sites More sharing options...
drewmandrew99 Posted April 18, 2023 Author Share Posted April 18, 2023 also found this under rom raiders experimental defs https://www.romraider.com/forum/viewtopic.php?f=34&t=9309 Link to comment Share on other sites More sharing options...
Infosecdad Posted April 18, 2023 Share Posted April 18, 2023 6 hours ago, drewmandrew99 said: also found this under rom raiders experimental defs https://www.romraider.com/forum/viewtopic.php?f=34&t=9309 Nice find, hopefully one of those two will work for you. Link to comment Share on other sites More sharing options...
drewmandrew99 Posted April 18, 2023 Author Share Posted April 18, 2023 Sent definitions to tuner apparently those were what we were using but he has a 2011 sti hes tuning Saturday so that will rule out a cable issue if that's all it is but looking like I'm gonna have to buy a new ecu if its similar to the ecu ID issue I linked above. Link to comment Share on other sites More sharing options...
m sprank Posted April 18, 2023 Share Posted April 18, 2023 I am not a tuner and even I kept at least two, if not three Tactrix cables on hand at all times. They do not have the most reliable usb input and I would have to resolder the boards now and then. All the signs that I should not buy another 4th gen are slapping me in the face. 2 Link to comment Share on other sites More sharing options...
drewmandrew99 Posted April 23, 2023 Author Share Posted April 23, 2023 Ok update #??? Tuner had no issues at all while doing the 2011 yesterday so it would appear it is an issue from my ecu. Now I do have an oppurtunity to buy a 04 forester for the super low because my roommates girlfriend is getting rid of it so wondering if by some miricale that ecu would work. Otherwise ill just hit car-part and get one its just further I got to drive. Link to comment Share on other sites More sharing options...
m sprank Posted April 23, 2023 Share Posted April 23, 2023 The Forester ECU will not work. SMH. Link to comment Share on other sites More sharing options...
drewmandrew99 Posted April 23, 2023 Author Share Posted April 23, 2023 assumed not lol Link to comment Share on other sites More sharing options...
drewmandrew99 Posted May 8, 2023 Author Share Posted May 8, 2023 Ok so new ECU is working with ROM Raider now so we got that, however, new problem is AFR correction is maxing out at 24.9% or whatever. Is this a sign of a bad fuel pump/filter? if so is the best route probably to just cop the high flow pump from cobb because they have that for $175 and apparently advanced auto parts wants $225 for a carquest replacement pump. Link to comment Share on other sites More sharing options...
Infosecdad Posted May 8, 2023 Share Posted May 8, 2023 AFR correction like that is probably more of a vacuum leak/bad MAF/etc than fuel pump. Link to comment Share on other sites More sharing options...
drewmandrew99 Posted May 8, 2023 Author Share Posted May 8, 2023 Already checked MAF and vacuum tested with tuner to rule those out that's what we thought at first. IDK what else it may be besides pump or injectors. injectors are suspect because I had 1 occurrence of a cylinder 3 misfire and am wondering if that injector may be going bad or if that was just a misfire from messed up AFR because it was before I got the AP tune but hasn't happened since. Link to comment Share on other sites More sharing options...
m sprank Posted May 8, 2023 Share Posted May 8, 2023 What is your AFR sensor (front O2) reading? What is your fuel pressure at idle? Link to comment Share on other sites More sharing options...
drewmandrew99 Posted May 8, 2023 Author Share Posted May 8, 2023 Tried to plug AP back in to look but forgot the cars got the first iteration of a rom raider tune and car shit itself and threw a code but unmarried access port and back to only shitting itself the previous amount. Having a guy look at it tomorrow though and I’ll update y’all Link to comment Share on other sites More sharing options...
m sprank Posted May 8, 2023 Share Posted May 8, 2023 Good Luck! Link to comment Share on other sites More sharing options...
drewmandrew99 Posted June 4, 2023 Author Share Posted June 4, 2023 Its been a hot minute since I updated but found my issue, the problem ended up being a clogged fuel filter, swapped it out and we are golden now. 1 Link to comment Share on other sites More sharing options...
m sprank Posted June 5, 2023 Share Posted June 5, 2023 Glad you got it sorted out. Link to comment Share on other sites More sharing options...
