Dreamnara8282 Posted January 6, 2023 Share Posted January 6, 2023 hi all, this is my first time having this problem usually after warm up, the coolant needle goes Hot or until Red line Hot and i turn on the Heater and after a while, the Coolant needle will drop to a little below center of Normal Temp. i was cruising at 70mph with Cruise Control on and it suddenly loss power so i pulled over four lights on Check Engine Light Traction Control Off S Mode or Sport Mode blinking Cruise Control light blinking i got 2 batteries, i've done this in the past as i did a Ton of traveling to various States and having a second Battery was a bit of peace of mind for me. any mods/toys are connected to the 2nd or Trunk/Rear Battery...not many toys but ANY help/advice appreciated! Link to comment Share on other sites More sharing options...
